Author Topic: twin screw single rudder, will it work?  (Read 10288 times)
Perkasaman2
Re: twin screw single rudder, will it work?
« Reply #25 on: December 12, 2015, 06:59:32 pm »
I'll watch this space.  :-)
Sandy
« Reply #26 on: December 12, 2015, 07:06:09 pm »
 :embarrassed:
However, I was meaning more from the point of view of rudder efficiency...  ;)
Surely, the thrust of the propeller is, in effect, a spiral tube or corkscrew coming off the blades, therefore offsetting the rudder in this corkscrew (dependant on rotation when going ahead) will increase its efficiency especially as you have one screw rotating one way and the other the other.
Sandy
Do try to keep up at the back there!
« Reply #27 on: December 12, 2015, 07:40:42 pm »
Twin shafts will give the hull more stability when on the plane as the thrust will be balanced each side of the keel.
Page created in 0.568 seconds with 17 queries.
