Author Topic: Taking a mould from a hull...  (Read 2524 times)
me3
« on: January 26, 2016, 06:30:13 pm »
I would like to attempt to take a mould from a hull that has been sprayed and is 'finished'. I would like to be able to take the mould without ruining the paintjob. Is this possible and if so, how would you do it?
Unsinkable 2
Re: Taking a mould from a hull...
« Reply #1 on: January 26, 2016, 06:56:39 pm »
Hello me, er you {-) . I have recently made a mould of a keel. First I made a wooden keel the same size and shape. Then I made sure it was sanded smooth. With your hull is it a smooth cross section, IE are there any ridges sticking out? If not then the next step is to make a box just big enough for the hull to fit in with about 3cm space all round. If there is a big space between the hull and the corners of the box then fill them with wood (screw them in!)
Next cover the hull with a few layers of good quality car wax and allow it to dry with each layer.
Next 80% fill the box with plaster. The corners filled with wood are cheaper than plaster!
Now push your hull into the plaster and hold it there with two batons screwed into the box sides. These stop the hull rising.
Once the plaster has set you should be able to ease out the unscathed hull.
Now the next bit I would clean the mould and then check for damage. If all is ok give it a few good coats of release agent (car wax or real release agent) then use your material of choice soaked in resine. It should give a smooth finish. It may need a little filler here and there but hey........ See 'Alantis' in yachts and sail for my plaster mould box........ Good luck. U2
« Reply #2 on: January 26, 2016, 08:03:16 pm »
U2's method best suits a hull that has no sheer or side detail where the concern about what is called 'draw' is not such a problem.
If you have any detail such as portholes, plating or the like then you need to make a two or even three part mould so that you can remove the pattern and hulls you make easily and with little or no damage to them or your mould.
The common method is to make a GRP mould and there are at least one tutorial on how to do this, and several members have made their own plugs and moulds to obtain a hull for their project.
Have a look in the Tutorials room and see if there is anything that will assist you.
markjames68
« Reply #3 on: January 27, 2016, 07:15:51 pm »
2 part mold at least, even 3 depending on bilge keel/ prop layout/ hull detail.
If you use a decent parting wax or even water based blue parting agent, epoxy resin wont damage the paint( polyester may well eat into it) You will be fine, with a little care......
 Wouldnt really consider trying to get even a simplish hull out of a 1 part mold, they can be buggers to get out if it they grab a little
