Author Topic: Oiling prop shafts  (Read 3142 times)
Mikecotton
  • The fifth attempt is usually the one !
Oiling prop shafts
« on: February 06, 2016, 12:24:42 pm »
My previous motor boats have been displacement types and I have packed the prop tubes  with silicone grease and then slid in the shafts. Having just built an Air Sea Rescue launch from the MMI July plans and as this is (hopfully) a faster type boat, I decided to oil fill the shafts. Is there a technique for doing this ? I used a 10Ml syringe and 5W50 motor oil but the back pressure forced the oil over my pristine - well nearly - interior. I have now left the syringe, without plunger, plugged in to the oiler tube and left it to, hopefully, seep in over time.
Is there a better way ?
Brian60
Re: Oiling prop shafts
« Reply #1 on: February 06, 2016, 02:57:24 pm »
Been a long time since I oiled a propshaft but we always used a thin oil like 3in1. I would say a motor oil although will do the job would add a significant drag to the shaft due to its viscosity.
Lithium or silicone grease is what I use nowadays.
Tug Fanatic
« Reply #2 on: February 06, 2016, 05:00:05 pm »
...................I decided to oil fill the shafts........................
I have only ever put in a few drops and repeated it occasionally. If you are not careful you might leave an oil slick across the pond.
Peter Fitness
« Reply #3 on: February 06, 2016, 09:34:03 pm »
This is a subject that has been discussed many times before on the forum, and there are as many opinions as there are replies. Some people believe that water itself is enough lubrication, others prefer various types of oil, and others, like myself, swear by grease. In my case, I always use outboard motor grease which is water resistant and does not emulsify when in contact with water. Some argue that grease puts an additional load on the motor by causing drag on the shaft. In my experience any drag is so minimal as to be inconsequential, particularly in the type of boats I run. It may be a problem with high performance vessels, but all mine are slow running, so any drag is not a factor.
I make all my own prop shaft assemblies, and silver solder a grease tube into the prop shaft tube, with a cap, as shown in the photo below. I use a small syringe to inject the grease into the prop tube, then add grease as necessary my filling the cap and pushing it over the grease tube.
Peter.
Mikecotton
« Reply #4 on: February 07, 2016, 12:38:58 pm »
Thanks for your comments and help. I was really asking for a less messy technique to get the oil in.
Guess it's back to the silicone grease ! When my tub runs out, I'll perhaps try the outboard motor grease ,Peter.
Thanks again all
Page created in 0.024 seconds with 22 queries.
