Author Topic: PBR Cannedheat (Deans)  (Read 8142 times)
tica
    • Skalamodelskibe
« on: February 16, 2016, 03:24:46 pm »
Just before Christmas I acquired a partly started Deans PBR "Cannedheat" it's a pre 2011 kit as it had the old instruction.
First step was to contact Deans for a updated build instruction which was mailed to me within a day  :-))
The kit was started, meaning many pieces was cut out including the hull, this was not done that good so I have had to fix some issues on the way to make everything fit.
I have chosen to fit a BL motor instead of the 385 type recommended in the kit.
I started out with the reinforcement of the edge of the hull
My postings are only reflecting my own opinion and should not be read as the holy grail of truth :-)
tica
    • Skalamodelskibe
Re: PBR Cannedheat (Deans)
« Reply #1 on: February 16, 2016, 03:29:05 pm »
Shaft and rudder assembly attached and aft deck in place. Motor is a Graupner BL 260Z 1380KV
tica
    • Skalamodelskibe
« Reply #2 on: February 16, 2016, 03:31:39 pm »
The front 2X .50Cal MG turret is assembled
And I found that the front part of te hull was cut too low so I had to add material on top for the last 100mm.
And a bit more work done
« Reply #3 on: February 16, 2016, 03:40:04 pm »
I keep looking at that model on deans website, so I'll be watching this one
Bob K
  • Bob K
« Reply #4 on: February 16, 2016, 04:06:07 pm »
I too will be watching this build with interest.  Dean's do very well thought out kits.
So nice of Ron to send you the build instructions for something someone else bought and only partly started.  Customer Service indeed  :}
« Reply #5 on: February 16, 2016, 10:23:27 pm »
Something a bit different to watch too  :}
« Reply #6 on: February 17, 2016, 12:23:17 am »
http://www.freerepublic.com/focus/f-vetscor/985489/posts
There's a nice photo of a Mk1 PBR control station on there - might help with detailing.
tica
    • Skalamodelskibe
« Reply #7 on: December 30, 2017, 09:36:44 am »
It has been some time since I updated this thread and some progress has been done.
Spraystrips
50cal and servo cover
Trim tabs
And some paint added, did have some challenges with my airbrush MAX DH-125 as it clogs up changed to mu old Badger 150 and it works.
« Reply #8 on: December 30, 2017, 03:02:04 pm »
Nice to see a few M60s as well as the ubiquitous .50 Cals Tica  :-)) You have leapt ahead with progress. Are you crewing her?
tica
    • Skalamodelskibe
« Reply #9 on: December 30, 2017, 03:20:10 pm »
And I do have some crew laying around and expect to add those in due time.
Next step is to tackle the supports for the tarpaulin, I'll do that in 1mm brass rode and see how it goes.
« Reply #10 on: December 30, 2017, 10:17:33 pm »
Good idea Tica. That will allow you to solder any braces or eyes to the hoops making them stronger.
tica
    • Skalamodelskibe
« Reply #11 on: February 17, 2018, 05:01:30 pm »
Well one step up and 5 back that's apparently the story with this build  >>:-(
For the last 4-6 years I have used Valejo paint including primer with good results in combination with a lacquer from Belton. Did the bottom and sides in one go and then the deck and what happened the paint on the deck cracked <:(
This is beyond my understanding. The primer and colour has been added in one go and is from the same bottles.  The lacquer used is the same can for both jobs ?
Well just have to strip the deck and redo it  :o
tica
    • Skalamodelskibe
« Reply #12 on: March 04, 2018, 10:43:25 am »
Ok fresh paint and lacquer and no problems this time.
johnv
« Reply #13 on: June 09, 2018, 09:15:33 pm »
Hi you are doing a grand job .I scratch built a 1/12 scale pbr there are photos of it on the mayhem at wicksteed park 2018 .Have a look it's 38 in long and 14 ins beam cheers John V
Peter57
« Reply #14 on: January 20, 2020, 09:12:14 am »
Hello,
I am pretty much a beginner with model boats, but I am thinking about getting one of these kits.
Does anyone have any thoughts please as to whether this kit is reasonably straightforward, or very challenging for a beginner?
Thanks in advance
Peter
« Reply #15 on: January 20, 2020, 01:03:00 pm »
Have you looked at Proboats alpha RTR bar battery
https://www.ebay.co.uk/c/12011025598
Peter57
« Reply #16 on: January 20, 2020, 02:00:58 pm »
Thanks. That could be an interesting alternative to the kit.
« Reply #17 on: January 20, 2020, 04:38:39 pm »
Good fun plenty of vids on Utoob https://www.youtube.com/watch?v=T3UVU36TDIw
tica
    • Skalamodelskibe
« Reply #18 on: January 20, 2020, 06:17:52 pm »
Hello,
Thanks in advance
Peter
I would not recommend it for a newbie and more or less not recommend it at all, most of the white metal fittings is not worth much, so for a nice result you have to redo a lot of them in thin brass and styrene/ABS.
This one is right now waiting for me to take the challenge and do the canopy.
And this build is also a bit worse than buying a new kit from Deans as this one was a partly started kit with a lot of extra challenges.
RegardsCarsten
Peter57
« Reply #19 on: January 22, 2020, 11:30:22 am »
Many thanks for your comments and advice. Much appreciated.
Peter
Dean's Marine
    • Dean's Marine
« Reply #20 on: January 26, 2020, 12:01:35 pm »
Peter
Peter
 some pics from the Vietnam group meet,
lots of P.B.R.s about, great fun to drive when set up right, so there are modellers who like them? plenty on U tube as well in actionhttps://www.youtube.com/watch?v=jJTs8J3u4SA
