Author Topic: What esc to use  (Read 3727 times)
Kraken08
What esc to use
« on: May 08, 2016, 05:27:20 am »
Hi, i'm new to rc scale boat and much help is needed.. :-)
Scratch built stern trawler:
Ikonnik Ka 6 channel tx/rx
12v 8ah sla
Mfa 919d 540 6:1
Futaba servo s3003 - rudder
Futaba servo s3003 - winch
40mm brass propeller
Fiberglass Hull L 762mm, B 228mm
Which esc?..
1. Electronize fr12vr 12amp w/bec
2.Mtroniks 15amp tio marine w/bec
Re: What esc to use
« Reply #1 on: May 08, 2016, 06:00:46 am »
Hi Kraken08,
Welcome to the  Mayhem!
The Mtronics speed controllers are much smaller and are waterproof, so they do have that advantage.
 (They are also a much more modern design... )
But these is nothing wrong with the Electronize, both have many advocates on Mayhem!
Kraken08
Re: What esc to use
« Reply #2 on: May 08, 2016, 06:44:21 am »
Since march i've been reading to this website and it helped me alot.. At first i was worried of the esc because if it cant handle the amp and breaks down then it would be much trouble to me because i'm from the philippines and shipping would take a month (return & shipping) i guess, But Now i'm certain that both esc can handle the mfa 540 6:1 motor.. Now purchasing 14 items from uk and if the delivery goes well then i'll be ordering again for my next project and reading more from this website.. I really like rc fishing trawler and rc tugboat.. thank you so much Modelboatmayhem :-) :-))
Re: What esc to use
« Reply #3 on: May 08, 2016, 08:41:20 am »
Mtronics ESCs are very compact sealed modules and in the unlikely event of failure need replacement rather than repair.
Electronize ESCs, in the equally unlikely event of failure, can be disassembled and repaired by replacing the failed component, but are bulkier than Mtronics.
Action ESCs are pretty good, too.
Re: What esc to use
« Reply #4 on: May 08, 2016, 10:01:35 am »
Welcome to the Forum.   :-))
It's always a good idea to get the highest amperage ESC's you can afford because you never know when you might  'upgrade'  the motor one day.
I would go for 20 amps at least.   %)
ken
phil_parker
    • Phil's Workbench
Re: What esc to use
« Reply #5 on: May 08, 2016, 03:18:49 pm »
Mtroniks for me. I use them in all my boats.
I have tried a couple of Electronize and found them fine for speed but noisy and less controlable for slow running.
Also had good response from Mtroniks when I've asked questions.
Subculture
    • Dive-in to Model submarines
Re: What esc to use
« Reply #6 on: May 08, 2016, 06:13:17 pm »
Microgyros FR40 is much better value.
chas
Re: What esc to use
« Reply #7 on: May 08, 2016, 11:33:48 pm »
Mtronics for me, never had one fail. Waterproof I regard as essential, whatever precautions you take, eventually they get wet.
Chas
Kraken08
Re: What esc to use
« Reply #8 on: May 12, 2016, 07:04:49 am »
Thanks for all the suggestions.. I now use mtroniks tio marine 30amp.. About my trawler i'm not sure which has more propulsion and faster
50mm propeller vs. 45mm propeller with 50mm kort nozzle
Both are using mfa 6:1 geared motor, 12v battery, m4 prop shaft, type A propeller
Fishing Trawler- Length 31 inches, Beam- 10inches
Have a nice day :-)
