Pages: 1 2 3 4 5 6 7 8 9 10 11 12 [13]   Go Down
Author Topic: Stril Barents- a Multi role vessel  (Read 98518 times)
Re: Stril Barents- a Multi role vessel
« Reply #300 on: January 29, 2019, 12:26:07 pm »
Yep the daughter boat, only those who are familiar with lipo could help, it would also be advisable to determine the weight that would be needed, say a few washers added and when at the limit then weigh them
Brian60
« Reply #301 on: January 29, 2019, 01:02:48 pm »
tsenecal
« Reply #302 on: January 29, 2019, 05:10:09 pm »
Are we talking about the daughterboat? Yep it floated ok just above the waterline with all running gear except a battery! I need a battery about half the size of  a pp3 that kicks out 6v - 9v and as light as possible  %% the esc has a bec built in so no probs there.
something like this will give you 7.5v to 8.0v at a much higher amperage than the 9v, and weighs less than half:   (link is just an example of what to look for)
https://www.ebay.com/itm/ZIPPY-350MAH-2S-7-4V-20C-LIPO-BATTERY-JST-MINI-MICRO-QUADS-PLANES-ROCK-CRAWLERS/272629203077?epid=886153868&hash=item3f79f78085:g:llgAAOSwAANY7vg0:sc:USPSFirstClass!80005!US!-1:rk:1:pf:0
Brian60
« Reply #303 on: January 30, 2019, 08:47:14 am »
That one is certainly worth exploring Tsenecal, although if it were 10mm shorter in length it would make fitting a lot easier. I'll see if I can source one in the UK or Europe and have a play around with fitment, offhand weight could be an issue, but I'll try warspite's idea of floating it with metal washers until I get to the waterline then see how much they weigh.
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 [13]   Go Up
Page created in 0.73 seconds with 22 queries.
