Author Topic: K&S tubing  (Read 2959 times)
Norman Castle
K&S tubing
« on: July 02, 2016, 01:11:18 pm »
Can anybody please tell me which size K&S tubing I need to make hinges with 18SWG piano wire?
Not really fussed if it's ally or brass.
A positive attitude may not solve all your problems, but with any luck it will annoy enough people to make the effort worthwhile.
Re: K&S tubing
« Reply #1 on: July 02, 2016, 10:52:47 pm »
Norman....when you do the simple calculations, you will see the nomination of #18 gauge piano wire @ 0.048" diameter is not a good selection for 1/16" OD x 0.014" wall, nor 3/32" OD x 0.014" wall K&S brass or copper tubing........... Derek
Kipper
  • Bodgitts Dry Dock Co.
Re: K&S tubing
« Reply #2 on: July 02, 2016, 11:01:28 pm »
You could try these people, they do 'needle tube'. http://www.graysofkilsyth.com/salmon-needle-tubes.htm
The 1.8mm o/d tube may well be about 1.3mm internal, which would just fit your 18 piano wire.
Im gonna need a bigger shed.
Re: K&S tubing
« Reply #3 on: July 03, 2016, 01:35:16 am »
Norman......just thinking outside the square.......
You could consider 1/16" OD [0.0625"] K&S brass round stock with K&S 3/32" OD brass tubing
These two sized elements provide a reasonably firm telescoping tolerance and both suitable for soft or silver soldering
The 1/16" OD brass material is only approx. 0.014" larger than your #18 gauge wire
Norman Castle
Re: K&S tubing
« Reply #4 on: July 03, 2016, 10:59:08 am »
Got there in the end ...
K&S 5/32" nominal ally tube + 18SWG piano wire makes me a satisfactory hinge  :-)
Norman Castle
Re: K&S tubing
« Reply #5 on: July 03, 2016, 03:00:42 pm »
Just realised I typed 5/32" instead of 3/32" ...  :embarrassed:
Norman Castle
Re: K&S tubing
« Reply #6 on: July 04, 2016, 12:56:44 pm »
And I now know that brass tubing in SWG sizes from 20 up to 6 is readily available  :-)
Page created in 0.039 seconds with 22 queries.
