Author Topic: Gel cell battery questions  (Read 7485 times)
flag-d
« on: May 30, 2006, 05:15:28 pm »
Hello all
Background: I'm running a pair of Yuasa NP7-6 (or is it ...6-7?) gel cells, 7Ah 6v, in series to give me 12v to a pair of mTronik Marine 15 ESC's, each of which runs a pair of Graupner 500E motors.  I use a Robbe Lader 6 battery charger and charge the batteries as a pair at 500mA.  Hope all that makes sense.
Questions and problems: here goes...
1. Around Christmas time, I snagged weed around a prop and put a very heavy drain on 1 motor which badly affected 1 cell in one of the batteries.  Badly affected in that it would no longer take a charge.  Took it back to the shop and clever man put affected battery on whizzy charger (gave it lots(?) of amps) and said it was now OK.  Please explain (short words, please, not too many syllabubs).
2. I now appear to have a similar problem on 2 more of the same type of battery.  I don't think they're taking a charge, or at least, 1 of them isn't as model appears very under-powered all of a sudden (yes, checked everything else).  How does this happen and can it be cured.
3. The Lader 6 charger is handy because I can charge the Tx, Rx and drive batteries all from the 1 unit and all at the same time.  However, I don't like the fact that there is no automatic cut-out once a set of batteries have charged, nicad or lead acid.  Can anyone recommend an alternative that won't over-charge nicads or lead acids?  Is it best to have separate chargers; nicad and LA?  Should I charge the batteries separately instead of in series?
4. I've heard that a lead acid which is fully charged will hiss slightly and a gel cell which is just about to be killed by over-charging will do the same!  Thoughts on this?  How does one tell, for certain, that a gel cell is fully charged?  They're not cheap items and I really don't want to trash any more than I really have to! (or burn the house down!)
5. What is the max current I can draw on those Yuasa batteries without destroying them?  I'd like to increase prop size and possibly motor size (to a 600) but don't want to fry the cells.
Thanks for taking the time to read.  Hope someone can help.
Jankers
Re: Gel cell battery questions
« Reply #1 on: May 30, 2006, 09:59:30 pm »
Hi Flag D,
I'm not familiar with your Lader charger but Nicads are normally charged at a constant current, whilst LA cells are charged at a constant voltage. This usually means two seperate chargers ( though modern equipment may offer both in one package?)
1. It is possible to 'repair' a damaged cell by giving it a huge charge of amps for a very short spell (seconds). It is normally a risky operation but is cost effective as a damaged LA battery usually ceases to operate if a cell goes down, so nothing lost really.
2 & 4. you will need to check with a multi-meter for both voltage and amps (not at the same time) to see if the battery is taking the charge. It may be too old? Wet LA batteries do deteriorate (think car battery, old style 'top-up') and I assume gels do likewise. Wet LA's do hiss at full charge, normally a bubbling of the gasses and this indicates a fully charged battery. Not sure about Gel cells for bubbling but if Nicads hiss this indicates the seals are emiting gass; usually a forerunner to failure. Nicad failure from overcharging is evident from the hissing and white deposits around the positive terminal. Cells may continue to work but at reduced max voltage.
5. See if you can pick up some info from yuasa/google.
Sorry I can't be more specific, I have very little experience of Gell cells. I understand these should be charged at 14.4volts (constant) and full charge is evident from the amp meter reducing to near zero (as per a car battery). Most chargers made for models seem to include a "float" option which switches in at the near full-charge point, generally indicated by some sort of LED sequence.
If modern eqipment allows both types of charging no doubt others will post, otherwise I should only ever charge a single battery at a time.
J.
Doc
« Reply #2 on: May 31, 2006, 06:33:20 am »
Mike,
If a gell-cell makes any noise, or if it appears to have swelled in some way, or if it gets warmer than you can hold, you have just broken a battery, junk it.  Gell-cells really are sealed, and need to stay that way.
 - 'Doc
PS - The only time you should hear a gell-cell is when it is humming a catchy country western or Celtic tune...
flag-d
« Reply #3 on: May 31, 2006, 08:30:56 am »
Jankers and Doc, thanks for the prompt replies.
Jankers: the Lader 6 is, on the face of it, a jolly good thing, as things go, as it has 6 charging outlets from 60mA up to 500mA.  The 500mA o/p is also the one recommended to use to charge lead acids.  The gel cell's are pretty new: only used/charged about half a dozen times so far, so I hope that doesn't make them 'old' as otherwise this hobby just got a lot more expensive!  wet LA's generate hydrogen durng charging, which causes the bubbling/hissing, which is normal.  Nicads hissing=good time to evacuate the building as far as I'm aware.  I've heard that a gel cell hissing in an obvious manner (stage whisper type of thing) is also a bad thing.
Doc:  Surely a gel cell must make some sort of noise as it charges?  I know that they're not liquid filled, as in the classic car battery type, but I believe the chemistry is the same and hence hydrogen will be evolved during charging and this has to vent somewhere.  If I ever hear one of my cells humming anything approaching a C+W tune, then it will be time for it to go!
Thanks fellas.  I think I need to do a bit more digging around on this subject.
bluesy
« Reply #4 on: May 31, 2006, 12:43:29 pm »
Just googled "gel cell charging" and found that the gasses ( hydrogen and oxygen ) created during the charging and discharging cycles are recombined inside the cells to form H2O which keeps the gelled electrolyte from drying out during repeated uses.
hope this helps......
doug
« Reply #5 on: May 31, 2006, 05:07:48 pm »
An individual cell has a chance of being "repaired" by zapping it with a lot of power.  Usually what is being tried is to blow off an internal short, a bit like blowing a fuse.  With a battery (several cells in series in one box, probably sealed), this form of mis-treatment is also being applied to all of its mates.  The original cell may be fixed, but the others may well have had their life shortened.
Follow Doc's advice - sigh a bitter sigh and sling it.  It is also quite possible that the internal short has discharged the gel-cell below the point where it will ever come back to life.
« Reply #6 on: June 01, 2006, 09:45:11 pm »
heavy discharge in a gell cell can cause  crystals to form between some of the plates, the high current zaps these off, thereby removing the short.
But if your motore are pulling heavy amps it will be worth changing to NiCad's.
ukengineman
« Reply #7 on: June 02, 2006, 04:37:43 pm »
A proper lead acid battery charger charges in a constant voltage current limited mode. As the battery reaches full charge (say about 13.8V for a 12V battery) the current will decrease to a low level. The Robbe charger has no ability to sense when the gell battery is fully charged and frequent overcharging will certainly shorten the life of the battery.
Alan
rats
« Reply #8 on: June 02, 2006, 05:28:28 pm »
   could anyone recomend a gell cell battery charger for a 12v 17A battery - all the chargers I have seen seem to be for a maximim of 12A ?
         cheers rats
Mankster
  • Wheelerdealer
    • RC Model Submarines
« Reply #9 on: June 02, 2006, 10:23:50 pm »
? ?could anyone recomend a gell cell battery charger for a 12v 17A battery - all the chargers I have seen seem to be for a maximim of 12A ?
? ? ? ? ?cheers rats
Why do these chargers have a max battery capacity? Surley they just take a little longer to fully charge. Smaller capacity battery limit I can undersand as the charge rate may be too high.
I use one of these http://www.mdsbattery.co.uk/shop/productprofile.asp?ProductGroupID=1039
Fast Electricals
« Reply #10 on: June 02, 2006, 10:54:55 pm »
There seems to be some confusion here over terminology. A charger that is rated at 12A can output a maximum current of 12 Amps. It could be used to charge a battery of over 200AH but will probably take about a day if it was flat. Small batteries such as the Yuasa packs cannot handle a charge current of much more than 1/2 Amp regardless of capacity and you will kill them if you try to charge them with a standard car battery charger. All lead acid batteries should be charged from a constant voltage. Initially they will draw quite a high current which will reduce as the battery charges up and approaches its maximum voltage. The best charger to use with a sealed gel battery is one that is voltage regulated and has a current limiting circuit. Leaving the lead acid batteries discharged will drastically shorten their life. These things are designed for alarm systems and similar applications where they are constantly tricle charged. Always recharge them immediately after use.
The process of zapping batteries can work with nicads but should not be attempted on lead acids. Wet batteries can suffer from sulphation on their plates which will reduce the capacity. There are some circuits available which can reverse the process electrically but the simplest method is to charge the battery for longer than would normally be necessary an leave it gassing for a few hours (in a well ventilated area). Gel cells should never be charged to these extremes as they are incapable of gassing without rupturing.
In my experience there is not much you can do with a low capacity sealed battery and they should be destined for the bin . Sorry, I mean the local recycling centre
« Reply #11 on: June 03, 2006, 10:19:27 am »
In my experience there is not much you can do with a low capacity sealed battery and they should be destined for the bin . Sorry, I mean the local recycling centre? ?
I agree about disposal, but in my experience the local tip (recycling centre to you - it says so on the notice) has staff who don't know the difference between a lead acid and Nicad battery or any other variant for that matter. "All batteries go in that bin mate" was the message I got last time I disposed some Nicads.
Green? positively mouldy
Doug
Daryl
« Reply #12 on: June 03, 2006, 11:08:52 am »
Gloucester council sold off the local tip a few years ago, now you have to pay if you take more than three bin bags or any other item like oil, batteries, electrical appliancies etc. Now the council wonders why fly tipping around Gloucester is on the increase!!!
Daryl
Guy Bagley
« Reply #13 on: June 07, 2006, 09:37:41 am »
 look at an optimate charger, very very good sealed lead acid battery charger and conditioner, - these were initially designed for use in the motor industry for keeping classic car batteries in tip top condition, but there is now one that is switchable from 12 volts to six volts, - these cost about ?39.... and they are worth every penny, they charge and then once the cell is fully charged they go over to 'trickle' charge to maintain the battery condition....
cbr900
  • Mayhem is the Only Forum!
    • Roys Hompage
« Reply #14 on: July 02, 2006, 05:00:08 am »
There is a charger made by MW which will charge ni-cads Metal nickel hydrides and gel cells correctly as it has enough knowledge to sort out which is which and then charge accordingly peak detecting when full and switching to triclke, I have been using one to charge all my batteries for the last five years and have not yet had a problem, the charge rate is also adjustable so you can set it for however you want to charge, they are not expensive either here they are $39.95 Australian which I guess would be about twenty to twenty five pounds..
Roy
Page created in 0.024 seconds with 23 queries.
