Author Topic: 80 inch Seaview sub  (Read 6994 times)
thegrimreaper
80 inch Seaview sub
« on: August 01, 2016, 01:17:32 pm »
Refurbishing (read rebuilding) this monster 80" of 1960`s T.V. and film stardom
Don't lie, thieve, cheat or steal. The Government do not like the competition.
spooksgone
Re: 80 inch Seaview sub
« Reply #1 on: August 02, 2016, 08:48:18 am »
Nice. Brings back a few memories of when I was a kid. Having said that, I still act like one now! :-)
imsinking
« Reply #2 on: August 02, 2016, 03:01:44 pm »
This a scratch build or a kit Mark ?
Didn't Morbeous do a kit many moons ago, (dont think it was this big tho')
If you get some of Keith's ESC's , it'll be very realistic with FIRE IN THE CIRCUITRY ROOM  %%
Bill  :P
TailUK
« Reply #3 on: August 02, 2016, 03:21:39 pm »
thegrimreaper
« Reply #4 on: August 02, 2016, 09:40:34 pm »
As far as I know Bill its scratch built and not Morbeus will not be using Kieth`s fire starters in her thanks and Thanks TailUK had that link for a while now Mr. Merrimen did an excellent job
Mark.
TomHugill
« Reply #5 on: August 02, 2016, 09:46:06 pm »
Kieths esc?
TheLongBuild
  • Build em, and play hard..
« Reply #6 on: August 02, 2016, 09:53:58 pm »
One of my dream builds, I got the plans from Taubman back in the 90's !!
imsinking
« Reply #7 on: August 02, 2016, 11:58:10 pm »
Kieths esc?
 {-)  A standing joke at our lake  %%
Bill
thegrimreaper
« Reply #8 on: August 03, 2016, 10:22:31 am »
Kieths esc?
meant Kieth`s ESC`s Tom as Bill said standing joke at our lake, imported ESC`s that let all the magic smoke out at the whiff of an ever ready
Mark.
sub john
« Reply #9 on: August 03, 2016, 07:17:26 pm »
HI Mark
     I really do like the look of the sea view that you are building i think it will be a very nice model, it is some thing different from the normal subs i would even be tempted to build it myself but i said i was not going to build another sub.
     All the best John
petesubman
« Reply #10 on: August 05, 2016, 11:05:46 am »
Hi Mark , this the boat that got me into submarines in1966 , made my first one out of balsa, my mum took pity and bought me the aurora kit for christmas, these are pics of my second scratch build around 80 inches along side the 57 inch deboer hull
thegrimreaper
« Reply #11 on: September 04, 2016, 05:26:53 pm »
I have now started on the rebuild/restoration of this 80" Seaview that I got hold of a few month`s ago, have taken a few photo`s so here go`s
I have decided to remove the window frames from the front four windows which incedently are not windows but are transparent hull plates as apparantley they were not fitted on the sub in the series, I have also thin`d out the spar between the windows as they looked a bit thick
thegrimreaper
« Reply #12 on: September 04, 2016, 05:30:20 pm »
I have also been busy with my dremmel tool and a few sanding drums to remove a massive amount of fibreglass from various parts of the inner hull both top and bottom I have also removed the old holding system for the Water tight tube from the top of the hull which you can still see in pictures these were strips of wood with brass hook type affairs which the tank hung from as far as I can tell
thegrimreaper
« Reply #13 on: September 04, 2016, 05:36:11 pm »
The next pictures show the state of play underneath the hull with all the flood holes that were in her I have refiled these holes with the intention of re-drilling less but bigger holes in the bottom of the hull
you can also see that I have cut out the area under the nose where the Flying Sub (FS-1) is housed, I cut this out due to it being the wrong shape and far to thick and heavy for what I want to do at the front of the sub
thegrimreaper
« Reply #14 on: September 04, 2016, 05:39:05 pm »
Next pictures show all the flood holes now re-filled and awaiting a tidy up with some wet and dry and lots of elbow work
thegrimreaper
« Reply #15 on: September 04, 2016, 05:42:13 pm »
I filled the flood holes in the bottom of the piece that I cut out under the nose with the intention of trying to make it lighter but gave up after finding out it was really thick fibreglass and plastic card and as I said earlier was the wrong shape as you can see from this picture. the hole in the hull has been filled with fibreglass and squared up at the front as it should be.
thegrimreaper
« Reply #16 on: September 04, 2016, 05:47:15 pm »
At this point I got hold of a pretty good set of Bluprints off the internet and noticed that the rear fins were set at to high of an angle so it was with great tripidation that I set about correcting this luckily the builder had fastened the fins on with screws which all snapped off on attempting to remove them so I resorted to brute strength and removed them with no damage to the main hull or to the fins themselves
thegrimreaper
« Reply #17 on: September 04, 2016, 05:49:51 pm »
After a few hours with plenty of water and wet n dry I had removed all the old fibreglass and filler that was holding the fins on I also removed most of the filler from the fins
thegrimreaper
« Reply #18 on: September 04, 2016, 05:51:23 pm »
First I refitted the left fin back onto the hull ensuring it was positioned in the correct place and at the right  angle
thegrimreaper
« Reply #19 on: September 04, 2016, 05:55:46 pm »
over the next few days I worked to ensure that both fins were in the correct position and both fins were at the correct angle once I was happy with the way they both looked on the hull I tacked them in place with resin finally fixing them in place with tissue and then resin and micro balloons, I think that I got the angle and look of the fins quite good
« Reply #20 on: September 04, 2016, 07:07:33 pm »
That has to be a labour of love.
You are doing a superb job following with great interest.
sharkbite0
« Reply #21 on: September 05, 2016, 05:45:53 pm »
chair pulled up and popcorn sorted.
my favourite program and submarine. this is looking great so far.
regards
mick
you only get one childhood so make it last all your life.
thegrimreaper
« Reply #22 on: September 15, 2016, 06:44:56 pm »
Build going a bit slower now due to work but I have re-profiled the sail dive planes and made up the Port  and Starboard rudders still got the centre one to make up yet but also built up is both of the rear dive planes
Regards Mark.
Page created in 0.021 seconds with 22 queries.
