Pages: 1 2 [3] 4 5 6 7 8 9 10   Go Down
Author Topic: RAF HSL whaleback in 1/16th  (Read 61126 times)
tghsmith
Re: RAF HSL whaleback in 1/16th
« Reply #50 on: January 30, 2017, 08:59:25 pm »
string or twine wasn't going to work for the detail in 1/16th.. found a good stateside supplier of scale rope. order arrived today.
http://www.syrenshipmodelcompany.com/
raflaunches
  • The Penguins are coming!!!
« Reply #51 on: January 30, 2017, 10:52:07 pm »
Wow, I've learnt some fantastic information on the gun turrets as for years we've tried to work out how to build a realistic looking versions for our Walton 65ft ASRL and we are going to use yours as a basis. :-))
Nick B
Illegitimi non carborundum!
tghsmith
« Reply #52 on: January 30, 2017, 11:43:11 pm »
thanks, I tried to see if I took a photo during the glue-up stage, but must have been not sure if it would work so it wasn't documented.. lots of half-lap filed pieces of bent aluminum all held in place by about twenty small alligator clips and twist of small wire..(slow curing filled epoxy helped by giving time to make adjustments) on the second one the main arches were set first and let cure making fitting in all the other ribs the next day much easier.. finding a small 1/16th wide flat file and a 16th dremel burr sped the making of the lap joints..needle files to clean up everything after..
roycv
« Reply #53 on: January 30, 2017, 11:44:12 pm »
Hi Nick, re Walton on Thames boat.  I have the magazine article with bulkhead cross sections showing a flared hull, quite different to the MM plans.  Also some detail regarding rudder tiller operation, that's from memory.
I mentioned this in another thread, perhaps you have this already.  I think I got the information from the RAF museum at Hendon many years ago, I think I saw a Mr. Lion there.
regards Roy
raflaunches
« Reply #54 on: January 31, 2017, 01:03:40 pm »
Hi Roy
Yes I remember that magazine, I think I've got one of the newer reprints.
The hull, and to be honest a lot of the fittings, isn't right but with a bit of research looking at the pictures of the original boat it can be built into a lovely boat. My Dad met a chap at Warwick in 2008 during the boat show who had built a fleet of 1/48 scale ASRL from original plans and he kindly sent a copy of the Walton plans to him showing the differences between the MM plans and the proper drawings.
Nick B
tghsmith
« Reply #55 on: February 03, 2017, 12:58:34 pm »
when you break off small parts and have to replace them..
tghsmith
« Reply #56 on: February 03, 2017, 06:43:54 pm »
added a few more tiny bits and some airbrush time
tghsmith
« Reply #57 on: February 08, 2017, 06:27:29 pm »
had to turn to aluminum to make sturdy light 20mm shield brackets,, pin bolted to the holes in the printed mount, should hold up to the rigors of a HSL..
tghsmith
« Reply #58 on: February 09, 2017, 09:34:55 pm »
nuts,bolts and a little paint..(never mind the little cork)
colin-stevens
« Reply #59 on: March 12, 2017, 04:10:00 pm »
Any progress on this project ? Hope you havnt given up.
grumpy old XXX
tghsmith
« Reply #60 on: March 12, 2017, 04:59:03 pm »
just got very busy with spring yard work, work work has been crazy.. and a cold that tried to move into my lungs.. hope to get some things done this week.. and want to get back on a few other projects in 1/96  and 1/48th
kees de mol
  • crazy about shipbuilding
« Reply #61 on: March 12, 2017, 08:09:10 pm »
beautifull work
Groetjes, Kees
tghsmith
« Reply #62 on: June 21, 2017, 02:24:17 pm »
spent any free time "updating" the column on my unimat to a adjustable milling unit,, did get the gun sight done,, weather here is starting to get hot and humid, so much for lots of yard work, time to get back to boat work in the air-conditioning..
tghsmith
« Reply #63 on: November 24, 2017, 01:43:08 pm »
work on this project is restarting after the summer off, found some great color footage of boats in action and have made some more great contacts.. the boat footage is in the last third.. red inside the vent cowls, an added stern plate, better views of the added searchlight..
http://www.eafa.org.uk/catalogue/933
tghsmith
« Reply #64 on: April 07, 2019, 12:50:22 pm »
not a dead project,, just have way to many things on the bench, a new milling machine for a live steam project.. but I had to do the glass work for a friends destroyer hull, seeing the whalebacks cabin mold was ready and the resin mess was happening.. the deck cabin was molded with balsa wood shaped and bent to between layers of glass clothe,, still needs filling and sanding,, but it seems to be  very light and strong ..
« Reply #65 on: April 07, 2019, 02:20:15 pm »
Beautiful Herringbone planking TGH :-)) .........
Couldn't help but recognize your workshop 1950's vintage Hospital bedside table....complete with the towel rail & pressed Lions Foot legs [on castors]  O0
tghsmith
« Reply #66 on: May 19, 2021, 11:54:20 pm »
have pulled the hull of the shelf and started work, marked the at rest waterline marks and ballested the hull in the test tank, I have 10 lbs to work with for the gear and fittings,, it will be just under 14 lbs total.. prepped the cabin mold and will lay-up hopefully a better cabin.. inspiration? the possible restoration of the last whaleback hull HSL 186,, and yes my model will be finished as the 186
tghsmith
« Reply #67 on: May 20, 2021, 11:14:49 pm »
the messy day,, but we have the second attempt at a molded cabin,, thin balsa sandwiched between cloth and resin, this time all the raised sections have balsa inserts, trying to keep the total resin amounts as low as possible.. hoping to get a strong and light cabin..
https://imagizer.imageshack.com/v2/640x480q90/924/GbGGCo.jpg
https://imagizer.imageshack.com/v2/640x480q90/924/d4o66c.jpg
tghsmith
« Reply #68 on: May 21, 2021, 10:39:24 pm »
the new cabin came out great,, won't take much work to get ready for primer, had a little free time and the resin was still out so the hull bottom section was given a layer of cloth..
https://imagizer.imageshack.com/v2/640x480q90/922/HgF4wW.jpg
https://imagizer.imageshack.com/v2/640x480q90/923/ny8GnE.jpg
tghsmith
« Reply #69 on: May 24, 2021, 10:55:42 pm »
trimmed up the hull, cleaned and trimmed the cabin, cut the basic openings and gave it a quick coat of primer so things can get marked out
tghsmith
« Reply #70 on: May 25, 2021, 11:13:03 pm »
turned a bottom edge on the turrets, bored and turned some pvc pipe to match, my spindle sander made quick work of getting the cabin holes to size..
gra2
« Reply #71 on: May 26, 2021, 05:00:00 am »
Looking good.
Graham
tghsmith
« Reply #72 on: May 26, 2021, 11:40:05 pm »
spent some time getting the cabin fitting to the deck better, a curved deck with camber makes things interesting, I knew the oblong window placements on the plans weren't perfect so some time was spent with photos to make a correct template,, now I have to machine up a form to make the 15 frames.. couldn't resist a few photos with some more of the details set in place..
tghsmith
« Reply #73 on: May 31, 2021, 06:51:41 pm »
awaiting in coming boxes,, stock for chine,rub and toe rails.. motors and ESC's. stuffing tubes, shafts and struts. Motor mounts.. extreme parcelanticapation!!!!
tghsmith
« Reply #74 on: June 01, 2021, 09:53:51 pm »
machined up a steel form to make the oblong window frames,, sliced up some aluminum tube that magically was the correct size,, with some gentle forming with vice and hobby hammer I have a correct looking nice and light frame,, now to make about 15 more and start cutting more holes in the cabin..
Pages: 1 2 [3] 4 5 6 7 8 9 10   Go Up
Page created in 0.181 seconds with 22 queries.
