Author Topic: SPEED 500E what esc?  (Read 4444 times)
hama
« on: September 27, 2016, 08:46:10 pm »
Hello!
I have two 500E that has run happily from M-tronics viper 15 for a couple of years. I have had some problems with them now and would like to try the Action range for a change. There are two 20amp esc as far as I can see, one is stated for 7-12 pole motors. How many poles are the 500E??
Thanks in advance!
Hama
Re: SPEED 500E what esc?
« Reply #1 on: September 27, 2016, 09:29:49 pm »
Economy motor with low current drain. Ideal for most scale model boats and one of our most popular motors
Specs
Nominal voltage 12 V Operating voltage range 6 ... 12 V No-load rpm 12000 min
No-load current drain 0,4 A Current drain at max. efficiency 2 A Current drain when stalled 10 A
Length of case, excl. shaft 50 mm Diameter 35,8 mm
Shaft diameterr 3,17 mm Weight 158 g
That's what I have found out I am SURE Mr MIlbs will be along shortly and advise you accordingly
inertia
« Reply #2 on: September 27, 2016, 10:57:48 pm »
P79.
DM
hama
« Reply #3 on: September 28, 2016, 06:30:28 am »
Thanks Dave no:1! Yes he came to rescue, Dave no:2.
Ok, so you say I can use the P79 that's good to know. It says on their site its suited for 380-400 motors but I guess you if anyone should know!
It's out of stock at the moment, I guess the P80 should work too if needed?
I don't want the P79S or P80S then?
Thanks very much for your help Dave and Dave M!
Hama
inertia
« Reply #4 on: September 28, 2016, 08:20:46 am »
P80 will be fine. You don't need the P80S for 5-pole motors.
DM
hama
« Reply #5 on: September 28, 2016, 09:37:54 am »
Thanks again! :-))
Hama
Klunk
« Reply #6 on: September 28, 2016, 04:48:34 pm »
http://www.gtmbc.org.uk/engines.html
P's my normal source for this info is not available at present!
full time penguin
Subculture
    • Dive-in to Model submarines
« Reply #7 on: September 29, 2016, 12:32:20 pm »
Just fit an FR40- job done.
inertia
« Reply #8 on: September 29, 2016, 05:37:38 pm »
I think you'll find that the OP specified "trying an ACTion ESC for a change". A second, more careful read of it will verify that.
While there is no doubt that the Microgyros FR40 is a fine example of the genre (I have one myself), it isn't an ACTion one.
I know, because I make those.
Hama
P79 will be back in stock shortly, or PM me and I can arrange for one to made up for you from service parts.
DM
hama
« Reply #9 on: September 30, 2016, 03:14:03 pm »
Very kind of you sir, but I'll either go for the P80 or wait for the P79. No hurry as I have to get funds first.
Have a nice weekend!
Hama
Page created in 0.022 seconds with 21 queries.
