Author Topic: Switches on light circuits  (Read 4280 times)
Captain Flack
« on: October 27, 2016, 04:05:23 pm »
I have several "revolving" yellow lights, actually they don't revolve they have 4 leds that light in a circular sequence.  They run off receiver voltage but have 3 wires into them, pos, neg & signal.  My question is how do I switch them, either manually or by a TX controlled switch as the TX switches I have only have the two wires on them and when I tried inserting a manual switch on the positive lead it seemed to wreck the unit.
Any ideas would be greatfully appreciated.
Re: Switches on light circuits
« Reply #1 on: October 27, 2016, 05:45:27 pm »
Do they plug into the Rx like a servo?
Captain Flack
« Reply #2 on: October 28, 2016, 09:12:31 am »
Yes, they do.
inertia
« Reply #3 on: October 28, 2016, 09:19:28 am »
In that case you may find that if you plug them into a channel which has a 2-way (toggle) switch on the transmitter to operate it then that will turn the unit on and off. I've had a look on E-Bay and those advertised seem to "plug into a spare receiver channel" e.g. http://www.ebay.co.uk/itm/RC-Rotating-beacon-AMBER-suit-Tamiya-13mm-dia-x-18mm-high-/301487892001
DM
Captain Flack
« Reply #4 on: November 01, 2016, 05:20:47 pm »
That doesn't appear to make them work either.  Course that could just be me :-) :-) :-) :-)
inertia
« Reply #5 on: November 01, 2016, 05:29:27 pm »
Hence my use of the word "may" and not "should"!
Generally 3-wire leads with receiver-type plugs on the end tend to fit into receivers, like the one I found (above link). Of course the whole thing might just be U/S...  <:(
Looks like it's back to E-bay, m'duck.
DM
Captain Flack
« Reply #6 on: November 02, 2016, 10:47:35 am »
Sorry, I think we may be at cross purposes here, my fault.  The units do work when plugged into the receiver, no problem.  I want to be able to switch them and can't.  I have them plugged into the gear channel and have set the necessary percentages, or so I believe , on an allocated switch but they still stay on.  I am unable to turn them off/on via a TX switch.
Am I right in assumimg that I should be able to do so or do I need a switcher?
Incidentally, they are exactly the same units as shown in your link.
« Reply #7 on: November 02, 2016, 11:50:34 am »
Try plugging in a servo to the same channel on the Rx, when you flip the switch, does it travel from one end t'uther?
Captain Flack
« Reply #8 on: November 02, 2016, 02:34:17 pm »
Will try that and report back.  Thanks.
« Reply #9 on: November 02, 2016, 03:08:43 pm »
Hurry up  :D
Captain Flack
« Reply #10 on: November 03, 2016, 03:47:46 pm »
The next thrilling installment {-) {-) {-)
I have plugged in a servo and yes it does move from end to end when the switch is moved.  I don't know if that's a good thing or bad {:-{
inertia
« Reply #11 on: November 03, 2016, 04:16:25 pm »
That's good for the servo and good for the receiver, but not so good for the beacon.
Try plugging it into a "normal" channel i.e. one with a stick, and move the stick from one extreme to the other, slowly. Does the beacon come on? If so, does the position of the stick have any effect on how it flashes? If not, then it doesn't do what the one on E-Bay allegedly does.
(Sometimes I feel like I'm talking to a puppy; please excuse me if it sounds at all patronising).
DM
« Reply #12 on: November 03, 2016, 04:21:21 pm »
Proves the Tx/Rx works ok on
The channel you are switching.
The Rx is supplying power and
sending a signal to the servo.
Need to look at the sequential
switching on the light unit next
I think.
And wot Dave said O0
Captain Flack
« Reply #13 on: November 04, 2016, 05:14:50 pm »
Thanks very much to all those who replied.  You certainly pointed me in the exct direction to get this problem sorted.
The lights I have are "exactly" the same as the ones in the above link, but when I bought them, a while ago now, there was no mention of the sequential lighting either on the e-bay blurb or on the packaging, so I assumed, wrongly, that they either rotated or not and could not work out why they didn't do that.
 But the problem has now been resolved and once again thanks to all those who took the trouble to post and help me out. :-))
