Author Topic: stainless steel railings  (Read 2951 times)
Rottweiler
« on: October 31, 2016, 09:26:36 pm »
Hi does anyone know where I can get this type of railing for my model warship please? they are usually available as 250mm long and  11mm high. Stainless steel
The only ones I can find are pretty expensive, and I need 14 lengths
Mick
nemesis
Re: stainless steel railings
« Reply #1 on: October 31, 2016, 09:37:41 pm »
Steingrabber, nice finish to a model but expensive. nemesis
nemesis
« Reply #2 on: October 31, 2016, 09:55:06 pm »
Just googled it to make sure, look up aeronaut/steingrabber for more info. You had better sit done first, they are £6 odd a length. But worth it for the result you get, I think they are nickel silver as they solder quite well . Also you can wiggle the stanchion free to line up if the gap is not right.Nemesis
Rottweiler
« Reply #3 on: October 31, 2016, 10:03:52 pm »
Thanks Nemesis,
They are the ones I found,but yours are a pound cheaper per length! Could you give me the link to the ones you found please? Thanks
Mick
nemesis
« Reply #4 on: October 31, 2016, 10:17:24 pm »
As I said in my last post, I googled steingrabber model ships railings and up it came.good luck. Nemesis
Geoff
« Reply #5 on: November 03, 2016, 01:57:36 pm »
Had you thought of using photo etch as you can readily purchase the stanchions - about 200 for £10/£15 range. You then thread them with 0.5mm brass wire or fine guitar strings. They are amazingly flexible and strong as well and may work out a lot cheaper.
I assemble mine off the ship into long lengths then spray them which holds it all together before fitting.
Geoff
Rottweiler
« Reply #6 on: November 03, 2016, 02:07:27 pm »
Thanks Geoff,
I had thought of using photo etched,but didnt fancy the idea to be honest.As well as the fact that my hands are very shaky,which makes things like soldeing or spot glueing,or even screwing in a screw,very difficult at times.
I'm all for the easiest way,which I think using the type of fencing I have chosen,the best option.
Mick.
Rottweiler
« Reply #7 on: November 07, 2016, 12:57:54 am »
I have sourced some of these rails from one particular establishment,but I have now to wait until monday for him to ring me back,after finding out if he has enough in stock for my needs,
I am not holding my breath,although as he said he has my number on his phone,he didnt take my name!
Its almost 100 quids worth of business he is being offered!!
Rottweiler
« Reply #8 on: November 08, 2016, 10:11:19 pm »
Well cut my last statement.
The guy did ring me back and he has sourced enough railings for me,and will deliver them to me at Warwick
Well done to Maritime-Models.co.uk
and thanks.
Mick
