Author Topic: Futaba 6 ex 2.4 ghz problem  (Read 3426 times)
« on: November 02, 2016, 09:46:45 pm »
Odd one here on Boat model 1 and 6 I am only getting  around 75% throttle on channel 3 ...Boat 2/3/4/5 are full throttle.
Cant seem to find out what is going on ...any suggestions.....
unbuiltnautilus
Re: Futaba 6 ex 2.4 ghz problem
« Reply #1 on: November 02, 2016, 11:06:41 pm »
Seems like an obvious question, but I will ask anyway..you don't have some sort of Rate set up which is dialled back for those two model memories, but not the others?
It is gone 11pm and I cannot remember what options are available on the 6EX!!
« Reply #2 on: November 03, 2016, 08:30:56 am »
Thats what i think is going on but cant for the life of me work it out !
Have reset everything but i think i have had this before but cant remember what i did last time
unbuiltnautilus
« Reply #3 on: November 03, 2016, 09:06:01 am »
EPA or End Point Adjustment is available on all four sticks, while DR or Dual Rate is only available on the sprung sticks, not the ratchet or throttle stick. It is worth starting there to see what settings you currently have programmed. After that, it gets puzzling!
« Reply #4 on: November 04, 2016, 09:58:40 pm »
Very odd one this checked the End Point adjustment and it was set to 140% on the throttle stick both fwd and back this was on channel 1 and 6...still the same with the throttle cutting out at around 75%
I then reset the EPA to 100%....still same results,then reset back to 140% and I now get full throttle on ALL the channels...weired as they were allready set to that.............................just cant explain it
inertia
« Reply #5 on: November 04, 2016, 11:30:44 pm »
Stav
It's either haunted or it's the Welsh water. Say no more.   ;)
DM
« Reply #6 on: November 05, 2016, 08:30:26 am »
Wrong Dave ....it's those darned locally supplied batts....they got WELSH ELECTRICITY in them
inertia
« Reply #7 on: November 05, 2016, 09:42:26 am »
What? All the way from Shenzhen??
DM
« Reply #8 on: November 05, 2016, 11:31:28 am »
SSSHHHH  dont tell everyone as they are ALL full of Welsh leccy m8
« Reply #9 on: November 05, 2016, 01:55:08 pm »
Hi Dave,
Try copying channel 2  to  channel 1.
Just a thought.   %)
Page created in 0.017 seconds with 22 queries.
