hi guys, just trying to figure out what width strips i should go for, after doing some math & looking at some plans, ideally i need around 30 planks to cover the width at the widest point of my deck (center probably) ..the total width at centre is around 450mm... so i'm guessing (btw i'm no expert at math!) i need strips of around 15mm width, problem is...largest i can find is 10mm width so it wont look scale & as im going to need alot, its also going to be pretty expensive so i want to make sure i get the correct size if poss!
Anyone know of anywhere that i can get Walnut)strips around 15mm width please?
Cheers guys/gals! :)
