Author Topic: Robbe f 16  (Read 4551 times)
ex docky
Robbe f 16
« on: November 16, 2016, 04:23:21 pm »
 I am in need of a robbe module 8370 to operate all of the controls on an Engel Gato.
Has anyone any idea where these an be obtained?
Thanks ex docky
TomHugill
Re: Robbe f 16
« Reply #1 on: November 16, 2016, 04:33:00 pm »
Only if you've got the retractable planes.
ex docky
Re: Robbe f 16
« Reply #2 on: November 16, 2016, 04:56:09 pm »
The kit I have has the retractable planes and the tmax dive system
HMS Invisible
  • MICROGYROS.COM
    • Yes, it works!
Re: Robbe f 16
« Reply #3 on: November 16, 2016, 05:11:13 pm »
Just the 8370 decoder alone or with the 8101 Multi-Switch-Prop 12+2 needed to work it?
ex docky
Re: Robbe f 16
« Reply #4 on: November 16, 2016, 05:27:14 pm »
I have the 8101 multi switch so only need the decoder
timgarrod
    • Alvaston Pirates Model Boat Club
Re: Robbe f 16
« Reply #5 on: November 16, 2016, 06:10:14 pm »
C-3PO
Re: Robbe f 16
« Reply #6 on: November 16, 2016, 06:15:45 pm »
Would be worth picking Tim's brain - Mayhem user "tscenecal" as he created his own solution
Really cheap option < £10 with an Arduino clone
https://www.subpirates.com/showthread.php?5285-Arduino-based-Robbe-multi-prop-decoder
C-3PO
timgarrod
Re: Robbe f 16
« Reply #7 on: November 16, 2016, 08:54:41 pm »
Just got my self a Arduino and was wondering if it was posible to link it to the swiches :)
Cheer C-3PO
tsenecal
Re: Robbe f 16
« Reply #8 on: November 16, 2016, 10:11:46 pm »
using a cheap chinese arduino, the sky is basically the limit as to what you could do with it.  based on some assistance i did with a user on subcommittee, the analog pot decoders that drive servos and the digital decoders that switch on and off switches use exactly the same protocol to transfer data over a single multiplexed channel of the transmitter/receiver link.  that protocol is described completely in the article/thread posted on subpirates, with additional code bits to drive two different simple servo drivers, one i2c, and one serial.  that bit of code to drive the servo drivers is all that would need to be changed for what ever purposes you intend.  to properly mimic a 12+2, you will need to add cost for things like relays and other items to imitate the on/off switches (or lights), but a simple arduino should be able to drive two servos with no added hardware.  i was basically doing all that extra work on my robbe fc-28 to get a total of 12 channels for extra bells and whistles on my Alvin.  i figured that being able to drive servos or things that acted like servos would be the easiest to deal with, since pretty much everything you can stick on a sub these days has some type of device it plugs into, that then plugs into a servo socket on a receiver.
i have bought several items from wetronic.nl as well, and they are also good, and work as well as the original robbe parts, at less than 1/3 robbe's cost.
what types of devices does Engel recommend to use to run all the extras in the Gato?  i presume they must be relays that can plug into a receiver...
Page created in 0.116 seconds with 22 queries.
