Okay. Such a large hull is beyond my own experience, is this a model boat? You will need thicker cloth than 48g. Also bear in mind the resin system you use. Epoxy works better with cloth, especially if you will be using many layers as it's a better adhesive than polyester, and thus the risk of delamination between layers is pretty much eliminated. The snag with epoxy is cost and curing, it's much more expensive than polyester, and you need a warm environment for it it to cure well.
You could also consider chopped strand matt with glass tissue on top to smooth out the finish. This works best with polyester resin, and will be fairly inexpensive.
