Author Topic: Silver Solder rudder..  (Read 3021 times)
tizdaz
  • Boom!
    • My RC TID Build
« on: January 03, 2017, 01:26:15 pm »
Hi guys,
ok im going to be using silver-flo 55 with a flux paste to make my rudder, question is do i solder both sides of rudder, im not too sure because if i do one side...and then the other, when i do the other side wont it make the previous side solder melt again!?
heres pic of what im going to be doing..
cheers
My large-scale TID Build Website:
http://www.tizdaz.co.uk
Facebook:
boatmadman
Re: Silver Solder rudder..
« Reply #1 on: January 03, 2017, 01:47:51 pm »
I always silver solder both sides of my rudders. As long as the gap between the rudder and spindle is v small, the solder will not flow out of the other side once you turn it over.
A tip: get some tipex, paint it all over the areas where you dont want the solder to go to. Take it up to within about 1 mm of the rudder spindle, do this before putting the flux on.
Once soldered, the tipex will be discoloured but will come off easily.
Ian
« Reply #2 on: January 03, 2017, 01:52:25 pm »
If it's hot enough, won't it flow through to both sides anyway?
boatmadman
« Reply #3 on: January 03, 2017, 01:55:47 pm »
Ooops!
I didnt look at the pic carefully enough. You are right Martin, it will flow through on a butted weld like that.
I make  mine with a slot in the spindle, hence my comments on turning over.
Ian
steamboat66
  • maybe it will float!
« Reply #4 on: January 03, 2017, 08:36:17 pm »
if the correct (small) gap is set, the solder will find its way through the slot. BTW, it won't drip off. if possible feed the solder in from the opposite side to the flame, the solder will flow to the heat.
« Reply #5 on: January 03, 2017, 09:20:21 pm »
If the metal is clean enough, is at the right temperature range and fluxed well, then the solder should flow freely. Too much solder will be more costly and take more time to clean the piece up after pickling.
tizdaz
  • Boom!
    • My RC TID Build
« Reply #6 on: January 04, 2017, 12:33:20 am »
oki doke,
so as long as i have the correct gap then just one side should be ok to solder as the solder will fill the gap on both sides?
Ive watched this vid (which is where i got the idea from) but in vid it only shows the guy soldering 1 side so im guessing thats all it takes:
https://www.youtube.com/watch?v=elECFvWR45Y
Facebook:
Page created in 0.064 seconds with 21 queries.
