Author Topic: Painting the bridge  (Read 2514 times)
glyn44
  • Flying Sailor
  • Pass the grog!
Painting the bridge
« on: January 09, 2017, 08:45:48 am »
Hello all,
I'm  building a pilot boat and am wondering what is the standard colour I should use for the inside of the bridge? If it is white(walls and ceiling) the is it normal to paint the ABS plastic as it is already white. The outer surface will be orange.
Hope you can advise please,
Regards Glyn.
Re: Painting the bridge
« Reply #1 on: January 09, 2017, 09:17:31 am »
Plastic with a layer of paint lasts longer, the paint makes a nice UV barrier.  White plastic tends to discolour noticeably in sunlight, coloured plastic probably does the same.  The paint also helps seal the surface against the plastic losing its more volatile components over time.
SailorGreg
« Reply #2 on: January 09, 2017, 09:33:03 am »
Google "pilot boat wheelhouse images" and you will get a selection of views of different boats. Mostly light colours but not bright white throughout. Take you pick!
Greg
glyn44
  • Flying Sailor
  • Pass the grog!
« Reply #3 on: January 09, 2017, 10:54:42 am »
Ok guys,
Pointers gratefully received, I will check out the images out. From memory, I have been on the bridges of about 6 boats, I think the merchant ones were white, and the RN grey. I'll mull it over, but will go for white, as I already got that paint in stock.
Thanks for you help, always appreciated,
Glyn.
Page created in 0.027 seconds with 17 queries.
