Author Topic: Caldercraft North Light  (Read 2963 times)
qkingston
« on: January 12, 2017, 06:22:15 pm »
Hi everyone,
My first post on this forum! Just starting the North Light model having done Artesina Latina kits previously. I notice that the GRP hull is supplied with extra material above the line of the top of the bulwarks; nowhere in the instructions does it talk about cutting this down to the correct height although the drawings clearly shows this must be the case. So assuming I have to do that, what's the best way to trim it down in height?
TVM
Corposant
Re: Caldercraft North Light
« Reply #1 on: January 12, 2017, 10:53:11 pm »
Hi TVM
It's great to have you on board! There's a huge quantity of knowledge and advice stowed in the hold.  O0
There are quite a number of people on the forum who have built Northlight. From your description, it would appear that the current hull differs a bit from earlier examples. If you can manage a picture, it will probably make it easier to advise. (There is a section on how to achieve this - sizing is important. I use Photobucket but I'm not sure I can recommend it - it can be a bit of a pain sometimes!)
Nemo
« Reply #2 on: January 14, 2017, 03:20:50 pm »
Welcome TVM.
If your photos are too large, I recommend this for re-sizing. Very easy to use and can also be used for multiple photos.
 http://pixresizer.windows10compatible.com/
Bob.
Now restoring an old 'Northlight'.
Corposant
« Reply #3 on: January 14, 2017, 10:51:51 pm »
I've just realized TVM stands for thanks very much!  :-)
qkingston
« Reply #4 on: January 29, 2017, 02:52:14 pm »
So on the inside of the hull above deck level, you see the unfinished (i.e. no smooth gelcoat finish), what do people do to get a better finish? I'd thought of a thin layer of filler then sanded?
Corposant
« Reply #5 on: January 29, 2017, 03:37:47 pm »
Sadly we cannot see your picture!   <:(
qkingston
« Reply #6 on: January 29, 2017, 04:20:14 pm »
Thanks Mike, I didn't add a picture, I meant the rougher surface is seen on the inside, how do people fix that?
Daleb
« Reply #7 on: January 29, 2017, 04:51:24 pm »
Hi qkingston,
I used P38 car filler for that job on my Caldercraft Milford Star...
Dale.
qkingston
« Reply #8 on: January 29, 2017, 05:38:08 pm »
Thanks Dale that makes sense
Rgds
QK
Page created in 0.998 seconds with 22 queries.
