Author Topic: PADDLETUG FORCEFUL BUILD IN PICTURES  (Read 14207 times)
Re: PADDLETUG FORCEFUL BUILD IN PICTURES
« Reply #25 on: January 26, 2017, 09:55:09 pm »
OH MY LIFE what a build I am I AWE of your craftsmanship
« Reply #26 on: January 26, 2017, 10:01:23 pm »
Top class workmanship aside (I love the way you did the stern framing:O) I am impressed by the labour saving ideas such as using a Setsquare and trysquare joined with a clamp to make a height gauge.
I doff my cap in your general direction Mr Bird.
John W E
  • I see no ships !!
« Reply #27 on: January 27, 2017, 07:55:41 am »
thank you all for the encouragement :-)
To answer the question about planking; it depends basically on the hull you are planking and the material you plank with - whether its best to plank longitudinal or diagonally - I did diagonally planking on this hull because I was following the instructions in the Model Boats magazine to start off with and then after a while I went my own way.   But, to prevent planks from twisting I had to use plenty of clamps over the stringers.
More pics to follow :-)   Sadly, though I seem to have lost some of the building of the superstructure and the funnels - Gone to the eternal bliss of the mysterious folders disappearing :-)
Knowledge begins with respect
John W E
  • I see no ships !!
« Reply #28 on: January 27, 2017, 07:59:18 am »
more pics  :-))
John W E
  • I see no ships !!
« Reply #29 on: January 27, 2017, 09:45:25 am »
John W E
  • I see no ships !!
« Reply #30 on: January 27, 2017, 06:55:06 pm »
John W E
  • I see no ships !!
« Reply #31 on: January 27, 2017, 06:59:51 pm »
hi ya
The answer the question regarding the paddles; they are made from 1mm thick brass - I purchased the brass sheet from Ebay a while ago
john
« Reply #32 on: January 27, 2017, 07:52:23 pm »
I like the drivetrain. Those are serious pulleys, I cannot imagine much getting in her way:O)
John W E
  • I see no ships !!
« Reply #33 on: February 01, 2017, 06:50:28 pm »
hi there been doing a bit more fittings and also planking the bridge top :-)
« Reply #34 on: February 01, 2017, 09:37:31 pm »
The planking either side of the paddle wheels look excellent. I like the angles going on.
« Reply #35 on: February 01, 2017, 10:34:31 pm »
Nice going bluebird  :-))...
Is the pump to provide simulated diesel engine intercooler overboard water discharge?....or a fire monitor supply?
John W E
  • I see no ships !!
« Reply #36 on: February 02, 2017, 07:00:56 pm »
Hi there
the pump is for the fire monitors  :-)) O0
John W E
  • I see no ships !!
« Reply #37 on: February 07, 2017, 05:07:09 pm »
hi there been busy making the anchor windlass from Plasticard and I turned the cable drums from aluminium and also the chain wheels
John W E
  • I see no ships !!
« Reply #38 on: March 06, 2017, 09:26:11 am »
Bit more
John W E
  • I see no ships !!
« Reply #39 on: March 26, 2017, 01:47:47 pm »
Well, today, she sailed for the first time at the Lake; and she did sail quite well.   She was a bit bow heavy so will do some trimming of the ballast.  I also had problems with the actual P40 mixer not responding properly - something else to sort out.
raflaunches
  • The Penguins are coming!!!
« Reply #40 on: March 26, 2017, 03:43:32 pm »
Hi John
Congrats on getting her into the water, she looks stunning and as you say a bit of trimming and she'll look brilliant both on the water and on the stand. :-))
Nick B
Illegitimi non carborundum!
missyd
« Reply #41 on: March 27, 2017, 04:38:29 am »
Very nice! :-))
Danielle
« Reply #42 on: March 27, 2017, 10:00:53 pm »
She looks gorgeous Bluebird. The anchor winch is a lovely piece of work. Ther is lots of model engineering happening on here at the moment and none of it fantastically complex which is good to show how it isn't always weeks of work on lathes and complicated guff like that.
riggers24
  • Just full of stupid questions
« Reply #43 on: April 12, 2017, 09:38:38 pm »
Beautiful build mate :-))  is the problem with the Mixer and the esc's being different manufacturers
I will finish the crash tender someday - Still got tooo many toys to play with
John W E
  • I see no ships !!
« Reply #45 on: April 13, 2017, 07:39:10 am »
Thanks for the comments mates; problem with the mixer is that one of the ESCs has a BEC built into it - and - sometimes the programme on the mixer doesn't recognise it for a bit.   :-)    soon sorts itself out.
If I want to sort the problem out properly - I will just disconnect the BEC and put a battery pack in it's place.
Problem solved :-)
riggers24
« Reply #46 on: April 13, 2017, 08:11:16 am »
Page created in 0.163 seconds with 22 queries.
