Got a new electric motor and thought I would do some testing.
Its a 540, 5 pole with a current max efficiency 5.75amps. no load 1.24amps 6v-12v useage.
I ran it on 6v 10 amp gel cell.
On a 35mm 3 and 4 blade props. I got reading of 10amps full throttle. 7.5amps /1/2 throttle in the bath operated by a electronize EC.settling to 5.5 amps in 10 seconds on 1/2 throttle
Out of the bath direct battery to motor wired I got 10amps settling to 7.5amps and in the bath directly wired I got 15amps Then removing the prop returning the model to the bath the reading dropped to 10amps.
I think I'll need to find another motor to power this boat as it is a 35 inches displacement hull or is this the normal for a low drain 540 motor ?
Previously a had a Johnstone 600 fitted, say no more as it was a National Grid power supply job.
Feel free to offer suggestions of any kind except the rude ones ,which I know.
Seaspray
