Author Topic: RN deck paint  (Read 8030 times)
Rob47
RN deck paint
« on: January 29, 2017, 10:59:07 am »
looking for suggestions as to either humbrol or tamiya paint would suffice for RN decks circa late 80's
Through to 90's
I will finish this model
T888
Re: RN deck paint
« Reply #1 on: January 29, 2017, 11:11:20 am »
Rob, I've always used Humbrol sea grey M27
Regards David
unbuiltnautilus
Re: RN deck paint
« Reply #2 on: January 29, 2017, 11:16:09 am »
Agree, I would also suggest Humbrol 67 fresh out of the tin. Before sun, sea and foot prints wears it down.
mudway
  • Model Boat Mayhem is Great
Re: RN deck paint
« Reply #3 on: January 29, 2017, 10:56:48 pm »
From 1968, the RN used either BS381C 632 Dark Admiralty Grey or 638 Dark Sea Grey for decks. Humbrol 5 and 164. Bad news, 5 is gloss for some reason in the Humbrol range. Using one for the deck and the other for the flight deck does help the look of a model.
From about 1990 they have used BS381C 640 Extra Dark Sea Grey, Humbrol 123.
Rob47
Re: RN deck paint
« Reply #4 on: January 30, 2017, 09:01:29 am »
Many thanks for replies.  Mudway for HMS Bristol circa 190-91 it looks like humbrol 123, would you agree?
mudway
Re: RN deck paint
« Reply #5 on: January 30, 2017, 09:09:59 am »
I'd say so, a member of our club is bullding a 1/72 scale one & that's his deck colour.
Rob47
Re: RN deck paint
« Reply #6 on: January 30, 2017, 09:29:02 am »
Thanks and I am 1/72 as well, will let you know result  :-))
mudway
Re: RN deck paint
« Reply #7 on: January 30, 2017, 09:37:29 am »
Christian's hull I presume.  :-))
Rob47
Re: RN deck paint
« Reply #8 on: January 30, 2017, 03:56:38 pm »
Correct  :} :}
Rob47
Re: RN deck paint
« Reply #9 on: February 06, 2017, 04:20:06 pm »
Quick update, having tried the Humbrol 123 I thought it was too dark as did the users but felt it was going the correct way, so ordered some made up in a matt spray to the exact BS number and also a can of  hull paint to exact match.  They arrived today and test pieces show spot on, matched the hull grey to my tin of very thick hull paint "liberated from paint store on Lusty,  Deck gray is great far more subdued than humbrol and a lovely finish.  The spray cans also have a little lever that allows adjustment of the spray pattern, very good.
So thanks one and all a good result in the end
pdq
Re: RN deck paint
« Reply #10 on: September 05, 2017, 01:47:52 pm »
Pardon my ignorance but I thought some of the RN decks were green, is that not the case? I am particularly keen to find out what the deck colour of HMS Active (type 21) is btw.
Re: RN deck paint
« Reply #11 on: September 05, 2017, 03:22:31 pm »
Active would have had Grey Decks
pdq
Re: RN deck paint
« Reply #12 on: September 05, 2017, 03:45:50 pm »
Many thanks Ned
unbuiltnautilus
Re: RN deck paint
« Reply #13 on: September 05, 2017, 06:29:54 pm »
As a rough guide, deck green went out of use by the end of the 1970s, so if Active was in service in the late seventies, it would have started life with green decks.
pdq
Re: RN deck paint
« Reply #14 on: September 05, 2017, 07:32:45 pm »
Thanks Rob  I wanted to model her soon after commissioning circa 1977/8 as she was fitted with Exocet and Amazon was not until later. Would you happen to know the Green paint spec/colour reference?
unbuiltnautilus
Re: RN deck paint
« Reply #15 on: September 05, 2017, 11:04:00 pm »
Humbrol 88 Deck Green seems the closest match to photos of the era.
mudway
Re: RN deck paint
« Reply #16 on: September 06, 2017, 08:39:44 am »
BS4800 14C39 was the colour and gloss too which is why ships were covered with dark green anti slip treads or had the metal ones welded on. When wet very slippery.
pdq
Re: RN deck paint
« Reply #17 on: September 06, 2017, 11:04:38 pm »
Thanks Mudway. Didn't realise it was gloss, must have been a b u g g e r  to climb up in the wet as you say!
mudway
Re: RN deck paint
« Reply #18 on: September 06, 2017, 11:48:10 pm »
The level of gloss shows up in some photos.
