Author Topic: Laser / water cut acyrilic?  (Read 3004 times)
« on: February 04, 2017, 02:39:12 am »
Evening All !
Can any Mayhemers cut out a simple sign for me?
4mm Acrylic clear sheet - Tincker cad file.
carlmt
    • Linkspan Models
Re: Laser / water cut acyrilic?
« Reply #1 on: February 04, 2017, 12:30:48 pm »
No problem for me Martin - other than your cad file.
Can you save it into a dxf format and do you already have the acrylic?  at 4mm thick it would be best to use cast acrylic as opposed to extruded if it is to be cut on a laser.
How big is the sign?
Carl :-))
« Reply #2 on: February 04, 2017, 02:51:28 pm »
Hi Carl,
Excellent! ... I didn't want to ask anyone directly...  :embarrassed:
I can buy a sheet of 4mm Acrylic and get it posted to you.
Size: 150 x 90mm
 I Tincker cad, it exports in .stl . obj or .svg .... any good to you?
carlmt
    • Linkspan Models
« Reply #3 on: February 04, 2017, 03:34:46 pm »
No problem to do the job Martin, but the exported file formats are no good I'm afraid.
It would have to be either .dwg or .dxf.  Tinkercad is a 3D package for use with 3D printers - for laser cutting I will need it as a 2D drawing.
Can you send me a hand-drawn drawing of what you are looking for, with dimensions, and I can draw it here and, if you are happy with it, cut it out.
« Reply #4 on: February 04, 2017, 03:53:53 pm »
I'll send you the stl, this will view it - http://www.viewstl.com/
« Reply #5 on: February 04, 2017, 08:37:32 pm »
Martin,
Just buy a Valentine card from the local petrol station on your way home, like every one else  {-) :kiss:
Doug
« Reply #6 on: February 04, 2017, 08:55:40 pm »
Page created in 0.039 seconds with 22 queries.
