Author Topic: wind shield  (Read 3282 times)
benidormbob
wind shield
« on: February 07, 2017, 03:34:45 pm »
Hi all, I have a Graupener Wesser fire boat on the bridge/deck where the boat controls are mounted there is supposed to be a curved wind shield that is obviously missing. Cannot seem to locate one on any of the sites. Any ideas please guys  Thank you
gregk9
    • Chasewater Model Boat Club
Re: wind shield
« Reply #1 on: February 07, 2017, 03:38:33 pm »
what about using some clear plastic sheet, available most model stores, as you can buy coloured plastic sheet, you can but clear or even tinted sheet too.
Best wishes.
Steve. G.
Re: wind shield
« Reply #2 on: February 07, 2017, 04:22:22 pm »
Yes, use clear plastic sheet. I doubt if it would have been tinted as that would affect the colour of navigational aids seen at night.
If you are lucky with the curvature of the base you might get away with a straightforward strip. Otherwise you will need to make a paper template by placing paper against the front of where the screen goes and drawing round the bottom to get the correct shape.
When you have got it correct, use Canopy Glue which dries clear and doesn't react with the plastic to secure it in place. Just use a fine paintbrush to apply it to the inside of the base and the uprights and secure the plastic in place with something while the glue sets. Don't use superglue or poly glue.
I have just had to make a similar windscreen for my fishery cruiser, see photos below. In my case each frame was made separately using Plastruct H extrusion (v. expensive!) and each pane had to be made and slid in separately. A very fiddly job, made worse as the screen base curves in two dimensions!
benidormbob
Re: wind shield
« Reply #3 on: February 07, 2017, 04:28:44 pm »
Thank's  guys :-))
Sonar
Re: wind shield
« Reply #4 on: February 07, 2017, 04:38:42 pm »
Your able to use any clear plastic for a windshield
Bending the plastic can be done using a hot air gun
However keep the gun moving from side to side and NOT still
As the plastic warms up it is very easy to bend.
Try with a scrap peice first
TailUK
Re: wind shield
« Reply #5 on: February 07, 2017, 05:06:06 pm »
Always check packaging for thin clear plastic that can be useful.
Big Ada
Re: wind shield
« Reply #6 on: February 07, 2017, 06:23:25 pm »
Cut strips from a 3litre clear Pop Bottle.
benidormbob
Re: wind shield
« Reply #7 on: February 07, 2017, 09:04:50 pm »
 :-)) :-)) :-))  Thank you all. Some great tips
Page created in 0.026 seconds with 18 queries.
