Thank you for your comments this is the silver solder I used a 55% silver solder
silver solder 55% is a cadmium free silver brazing filler metal. It combines a low brazing temperature with a short melting range. This silver solder is very free flowing and produces neat joints with small fillets. These characteristics make this product an excellent general-purpose silver brazing filler metal. In many countries it is accepted as the best cadmium-free alternative to the low-melting cadmium containing filler metals. For example, it is used as a substitute for alloys such as Easy-flo? and Easy-flo? No.2. Joints made with Silver-flo? 55 are suitable for seawater applications, being resistant to dezincification. The optimum joint gap for this filler metal at brazing temperature is normally 0.05-0.15mm.
General icon Ag Cu Zn Sn Si Melting Range ?C EN1044:1999 cdfree 55 21 22 2 630-660 AG103
Product uses: Can be used to join all the common engineering materials (excluding aluminium) such as copper, copper alloys (including, brasses, bronzes, gun metal, nickel silvers, aluminium bronze, copper nickel), steels including, mild, carbon, tool steel, stainless steels, low alloy steel), tungsten carbide and PCD segments. On large or difficult to wet tungsten carbide pieces specialised silver brazing filler metals containing nickel / manganese are often preferred.
Conditions for use: This filler metal is mainly used for brazing in air with a flux. In most cases Easy-flo flux can be used in conjunction with silver solder 55%. However, flux selection is application dependent. Please refer to JM technical department or flux product datasheets before selecting a flux.
As cadmium based silver solder is no longer available here in the Uk which I do prefer as it will form a larger fillet, the location grooves are quite deep cut with the aid of a slitting saw and tapering the edge of the blade would not help as this grade of silver solder does not like slack joints, my photo's are not the best but it is the blade that has fractured not a breakdown of the soldered joint, with hindsight I should have gone up a gauge with the blades they are 1mm next time it will be either 1.2 or 1.5mm with some tapering towards the outer edges, and yes the blades where normalised after the soldering process ,These blades have been tweaked a bit to give them some shape and I believe that this twisting not to mention the damaged blades being straightened has caused the fatigue at the root of the blade as this section is solid and will not twist like the blade plus the brass is in an annealed state after the soldering and is quite malleable.
