Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 ... 52   Go Down
Author Topic: MMM Portgarth build  (Read 452446 times)
poll
Re: MMM Portgarth build
« Reply #400 on: April 27, 2017, 09:42:41 pm »
   Brick layers line is good. What about the Afon Alaw you have for Saturday?
T33cno
« Reply #401 on: April 27, 2017, 09:45:03 pm »
Thanks John
The Afon isn't built to tow as it has too much deck furniture. When my Portgarth is finished I may dismantle the whole caboodle and build it my way as I already acquired plans etc. :-))
EDIT actually it would be more sensible to sell it on and buy a hull
T33cno
« Reply #402 on: April 27, 2017, 09:54:19 pm »
poll
« Reply #403 on: April 27, 2017, 10:00:21 pm »
  yes that is fine
T33cno
« Reply #404 on: April 27, 2017, 10:08:43 pm »
  yes that is fine
£7.34 delivered for 85 metres, should last a while  {-)
Kevgarth
« Reply #405 on: April 28, 2017, 05:02:34 pm »
Following on from our telephone conversation earlier Andy please find attached photo's that are to hand of my Portgarth model as I'm still waiting for the sun to come out here in Bristol for another photo session, I'll see if there's anything else that be handy for your build and bring it up to Doncaster.
Kevin
T33cno
« Reply #406 on: April 28, 2017, 05:09:03 pm »
Yup thanks for the call  :-))
How do I do those window frames on the wheelhouse ?
Just one of many questions to come  8)
Kevgarth
« Reply #407 on: April 28, 2017, 06:28:36 pm »
Cut all the panels and offer them in position and once your happy with the shape of the wheelhouse it's then you mark the cut-outs for the windows as then the windows are parallel with the joint of the wheelhouse, I hope that makes sense???
Kevin
T33cno
« Reply #408 on: April 28, 2017, 07:08:18 pm »
Yes I understand that Kevin but I meant the window frames? Is it styrene or something etc
Or should I say surrounds?
Kevgarth
« Reply #409 on: April 28, 2017, 07:15:01 pm »
The way I done mine was to cut the perspex to the shape of the cut-out then fix plasti-card to the outside edge in doing this you're forming a rebate and then your glue it into position and this way you've got a nice joint on the outside edge.
Kevin
T33cno
« Reply #410 on: April 28, 2017, 08:28:31 pm »
Kevin
8)
T33cno
« Reply #411 on: April 28, 2017, 08:35:27 pm »
Next up for general circulation!
Resin brushes. The ones from hobby craft are cheap but as reviewers say the bristles come out in use  >>:-(
I tracked down ones by "Great planes" as sold at Leeds Model shop but LMS want 25p each and would only drop to £33 per box of 144 which I thought was a miserly discount.
I just bought the same by mail order for £27 delivered  :-))
No personal connection I swear!! just sharing FYI
https://wheelspinmodels.co.uk/i/279331/?gclid=Cj0KEQjw0IvIBRDF0Yzq4qGE4IwBEiQATMQlMdoDcbGu7kroK265yvgKVgLhRujvPcin0MF_s1A1tmQaAsef8P8HAQ
T33cno
« Reply #412 on: April 28, 2017, 09:49:45 pm »
Never going to match the authenticity of Kevin's but Will do for now and as it is easily replaced I have the option in future
This could be a finished section in very little time with a Matt lacquer hatch satin lacquer steel and a nice canary yellow D area finished with the SS socket screws  :-)
chipchase
« Reply #413 on: April 28, 2017, 09:57:38 pm »
Kevin
She looks good on the water Kevin :-))
chipchase
« Reply #414 on: April 28, 2017, 10:00:13 pm »
She is coming along Andy you will have her at Balne Moor before long, and show poll how its done LOL
T33cno
« Reply #415 on: April 28, 2017, 10:03:36 pm »
I doubt that but perhaps John will tutor me  :-))
Just now the decks depend on this winch motor arriving tomorrow. I need to make it function and fit it in a manner that I can remove it for service if required. Much paxolin involved  {-) .
I'm looking forwards to remodelling the washports and starting on the ribs
T33cno
« Reply #416 on: April 29, 2017, 12:14:16 pm »
This will be a testing process  :o
T33cno
« Reply #417 on: April 29, 2017, 02:26:57 pm »
Here we go Mike!  5rpm
https://www.facebook.com/Techno100/videos/10155168983877593/
Literally just fits with 1mm clearance and I can remove with just two socket screws on the main hatch shelf  :-)
FYI
T33cno
« Reply #418 on: April 29, 2017, 05:23:30 pm »
That has been quite a tense hour
The worry being that I made the mistake of drilling and tapping the Kort hatches earlier and if I didn't position the deck spot on I'd have a serious misalignment. However it has gone well with all surplus resin scraped off and hatches fit perfect. I've also produced a stencil to spray the yellow danger area.
I've been painstaking in ensuring that no edges were missed with resin as I don't want any water penetration between the ply and the paxolin.
Please offer me suggestions for the Gog as the MMM one isn't suitable for a working model
T33cno
« Reply #419 on: April 29, 2017, 05:55:56 pm »
That's my main hatch now awesomised  {-)  absolutely delighted and when the sealing gasket is fitted it will be a perfect flush finish.
Now I can treat the hatch as a separate unit and paint finish it  :-)
Note to self . Remember the battery screwdriver!!
Edit  I think I'll paint the crew heads too but leave the hex socket unpainted
« Reply #420 on: April 29, 2017, 08:05:49 pm »
Looking good Andy. The winch motor though a touch noisey looks like it does exactly what you wanted it to do.
What is a Gog?
T33cno
« Reply #421 on: April 29, 2017, 08:11:27 pm »
Thanks Ian
It will wear in and be less noisy I believe but it sounds louder because the sound is resonating through the bench. I'm not sure it's what I want but if it's good enough for Mike (Butts)  :-))
EDIT however Mike's is a larger circumference drum but I could not have accommodated that anyway so it will have to do. Quite fortunate really that the size I made happened to JUST fit.
The gog is the iron hoop at the rear of the deck that tethers the tow line to prevent it going too far to port of starboard. I stand to be corrected tho  {-)
T33cno
« Reply #422 on: April 29, 2017, 08:32:33 pm »
Further more I calculate my drum will wind 625mm per minute which I guess will do?I'm not sure how far Butts has gotten with his winch but this is what I'm doing.
This is my rope guide hole and I've countersunk it on the underside
Here it adds strength as a bonus and the rope exits and is directed over the dummy deck winch and off to la derriere . I'm going to fit a guide tube above deck so deck wash don't go down there.
Component shop must love me  {-)  and I'm not finished
T33cno
« Reply #423 on: April 30, 2017, 10:14:12 am »
My chosen deck & roof finish.
Left Halfrauds red primer and right with matt lacquer
Subtle Satin on Renault royal blue. Looks rather lighter here than to the naked eye
T33cno
« Reply #424 on: April 30, 2017, 12:21:42 pm »
Without trying I've managed to not make it look perfect  {-) but I'm happy with it  :-))  and when it's gone completely matt it will do me  :-)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 ... 52   Go Up
Page created in 0.219 seconds with 18 queries.
