Pages: 1 2 3 4 5 [6] 7   Go Down
Author Topic: Smit Rotterdam Build  (Read 52806 times)
Paul2407
Re: Smit Rotterdam Build
« Reply #125 on: May 14, 2017, 11:05:54 pm »
Looking great Terry, most of what you see now won't be seen in a few week time so no panic  :-)) you're doing a grand job though
FrozenRabbit471
  • Long may you big jib draw
    • My Instagram
« Reply #126 on: May 14, 2017, 11:14:17 pm »
Thanks! I feel encouraged by you guys.
Better to have it and not want it, than to need it and not have it
FrozenRabbit471
    • My Instagram
« Reply #127 on: May 16, 2017, 03:54:31 am »
Question guys, the acetate indicated  here, is it merely used as a test fit sheet? A couple guys suggested thick paper. This  would allow the superstructure to go on and come off the boat easily.
In the diagram, it shows a a pretty big piece, that eventually disappears in further diagrams.
Just a wee stumped.
FrozenRabbit471
    • My Instagram
« Reply #128 on: May 16, 2017, 04:43:42 am »
Hi all,
I couldn't decide where to place my query as the margins for the subject are so wide. The answers are so vast, it almost becomes complex.
I'm building the Smit Rotterdam by Billing Boats 1:75 scale. I am about to start sanding. I have applied non-polyester resin and 3/4 oz fibreglass cloth to the inside of the hull. Solid as a church! Looks great.
Most builders share either home made ideas or suggest fillers by brand name. This serves well if you're near the same county, province, state or country.
I want to fibreglass the outside of my hull after I have it all filled and sanded smooth. I'd like to know what type of filler is compatible with the type of resin / fibreglass I am using?
Much appreciated mates.😊
« Reply #129 on: May 16, 2017, 10:10:11 am »
I use car body filler, as this will accept fibreglass resin and can be sanded smooth.  Get the sort that doesn't contain 'bits of chopped matt' as you want it smooth before covering.
hope this helps
« Reply #130 on: May 16, 2017, 03:22:03 pm »
If it is car body filler then any resin and matt will be compatable
FrozenRabbit471
    • My Instagram
« Reply #131 on: May 18, 2017, 12:56:11 am »
Thanks Dave
FrozenRabbit471
    • My Instagram
« Reply #132 on: May 18, 2017, 12:58:19 am »
Hey all,
Here is where I'm at right now. Deck 3 cabins.
FrozenRabbit471
    • My Instagram
« Reply #133 on: May 20, 2017, 12:57:36 am »
 %% Wait, hang on! This is the first time I ever used fibreglass putty. I have no finesse in my hand to spread and feather this stuff out.
The initial coat "IS" on right and in every crack, but I think I added too much hardener. That and the amount I put on is a learning curve. It appears to be an epic fail, but she will be a fine ship when I'm done.
« Reply #134 on: May 20, 2017, 11:59:03 am »
Kenny (Tug) applied lots to his Queen mary some weeks back and look how well that came out! Mind you, he may have used standard repair filler and not the glass reinforced type but it will be interesting to see how it goes.
Will there be copious amounts of glass particles? If so do wear a mask and coveralls, and perhaps sand it down the bottom of your garden!
FrozenRabbit471
    • My Instagram
« Reply #135 on: May 20, 2017, 12:46:46 pm »
Wish me luck. I'll keep you updated. fingers crossed
Brian60
« Reply #136 on: May 20, 2017, 04:00:55 pm »
Sorry I'm late with a reply however I don't think anyone answered about the acetate. The reason it is there is to allow you to assemble the superstructure in situ so you get as tight a fit on the coaming as possible, the acetate stops any excess glue bonding it to the deck until you can remove it to the workbench.
Brian60
« Reply #137 on: May 20, 2017, 04:04:46 pm »
Also there are two types of body filler - the one sold in Halfords for diy use, its quite a 'thick' medium and the hardener supplied means that it sets up quite quickly - typically within 5 minutes.
There is also a type available to the trade (which should be available at your automotive paint suppliers), it is more of a fluid medium, more runny and easier to spread, it also takes longer to set, working time of 20 minutes is normal.
Mark T
« Reply #138 on: May 20, 2017, 06:03:44 pm »
This is what I thought too....If you do not have any acetate I have successfully used sellotape on the past for this purpose.  Also a tip for applying filler is to put many thin layers on rather than trying to get it filled in one hit.  This has always worked for me and saves lots of elbow grease!  Keep at it as I'm sure you build will turn out great  :-))
FrozenRabbit471
    • My Instagram
« Reply #139 on: May 20, 2017, 07:23:18 pm »
The kit doesn't supply acetate so I used parchment paper. It give me a precision fit. I have the bow section glued together but not to the boat yet.
The hull has been completly filled, sanded and another fill in certain areas. Ill sand that tomorrow. I've also sanded the window holes a little bit to add some realism, shown in the photo. It hasn't been fine tuned yet.
FrozenRabbit471
    • My Instagram
« Reply #140 on: May 20, 2017, 09:25:04 pm »
thanks skipper
FrozenRabbit471
    • My Instagram
« Reply #141 on: May 21, 2017, 10:32:13 pm »
I did some more sanding and filling, working tiny amounts on the bow face and shaping the bell the way I want it.
 had that done by 11 a.m. and feel guilty (haha) not working on the superstructure today. But hey, the real Smit Rotterdam wasn't built in a day.
Slow & steady
FrozenRabbit471
    • My Instagram
« Reply #142 on: May 31, 2017, 04:09:32 pm »
Hey all,
I haven't given up. I've simply got derailed by life. I Have done a small bit of work on the lower superstructure in between.
I hope to get back at the hull and get my RC components soon.
Terry
SailorGreg
« Reply #143 on: May 31, 2017, 05:15:08 pm »
No rush Terry.  The idea is to have as much fun as possible, so the longer it takes, the more fun you have!   :}  There are some around here (me included) whose builds run into years.  Imagine how much pleasure we have derived from simply cutting and sticking bits of wood and plastic!   ;)
FrozenRabbit471
    • My Instagram
« Reply #144 on: May 31, 2017, 06:23:39 pm »
I already have places and ideas for "bits & bobs" !
FrozenRabbit471
    • My Instagram
« Reply #145 on: June 02, 2017, 02:58:37 pm »
I've discovered the initial bulk filler application over the hull was the easy part.
The later stages of smaller amounts of filler is like pulling teeth. Very tedious.
It's all a part of it I guess. I am either very lucky or actually have some hidden skills to have pulled of a successful hull despite the not so perfect planking.
The easy part of the build is all behind me now. This is where patience and time really kicks in. I am still loving it.
FrozenRabbit471
    • My Instagram
« Reply #146 on: June 02, 2017, 04:39:35 pm »
The bow & bell are working out great. It's obviously not completed yet. Fill and sand, fill and sand. To the non builders, it doesn't look very good, but it's only due to the various shading of fillers.
The paint and wax will prove to be a masterpiece for this amateur!😁
« Reply #147 on: June 02, 2017, 08:06:15 pm »
Even the small amounts of filling and sanding I have done to date seem like marathon jobs, but you do get there in the end.
She's looking good  :-))
FrozenRabbit471
    • My Instagram
« Reply #148 on: June 04, 2017, 05:46:58 pm »
This is just the first coat of primer to show me the hills, valleys and pinholes. I have some more light fill and sanding.
Some areas "look" rough, but the lighting and shading accounts for some of it. This hull is a solid as a church. The inside is very rigid as it's epoxied with fibreglass cloth..... and two clothes pins!
« Reply #149 on: June 04, 2017, 11:14:16 pm »
Cor, you are zooming along!
Pages: 1 2 3 4 5 [6] 7   Go Up
Page created in 0.021 seconds with 22 queries.
