Apart from the voltage, there are two current ratings for any switch. One is what it can switch, the other is what it can carry once switched unless the thing has been arranged to instantly use full power. A master switch will not normally need to switch anything like the eventual load that it will carry, since the additional load will arrive later.
What it can switch off has an effect on contact life as well - at the instant of breaking, the voltage (either raw or back EMF if chopping an inductive load) usually creates an arc which eventually, over a lot of operations, creates pitting. Anybody remember filing contact breaker points?
If in doubt, get the big 'un. This applies to much in life.
