Author Topic: 1:35 Scale canal boat  (Read 9361 times)
Hesky
    • Hesketh Scale Models
« on: June 12, 2017, 08:35:16 pm »
Hi all,
Thought I would show my build of a 1:35 Scale canal boat from 3D printed parts, resin castings and etched brass. I usually build 1:35 model railways but always wanted to incorporate canal boats on my next layout.
The model has been designed from plans of a Royalty Class boat which had steel hulls and built in the 1930's. The hull scales down to just over 60cm's in 1:35 scale.
Anyway I will post pics over the next few days if I work out how to attach them,
Hope it is of interest,
IMG_5006 by Mark Hesketh, on Flickr
IMG_4990 by Mark Hesketh, on Flickr
IMG_4988 by Mark Hesketh, on Flickr
More to come,
Mark
Re: 1:35 Scale canal boat
« Reply #1 on: June 12, 2017, 08:54:48 pm »
Very attractive Mark  :-)) How thick is the brass? Seeing the edge of the cargo sides suggests less than .5mm but the size of the model might be misleading.
Hesky
« Reply #2 on: June 12, 2017, 09:07:47 pm »
Hi there,
Thanks for the comments
I always use 12 thou brass which is approx 0.3mm at full thickness, the boat is about 60mm width which makes it a bit easier to judge.
The whole hull was originally 3D printed in one part but I have since taken a mould and cast a few in resin which reduces the overall price considerably.
Mark
« Reply #3 on: June 12, 2017, 09:11:49 pm »
At the moment it would indeed be cheaper to cast them yourself. Do you sell them or are you building a fleet of barges? I suppose you could cut the ends off of a resin hull and insert the cargo section or a part, to build a longer barge.
Hesky
« Reply #4 on: June 12, 2017, 09:27:52 pm »
I originally wanted to make just 2 or 3 and really enjoyed designing it so may release it as a kit. I'm already drawing another design of an earlier boat on CAD which has been just as interesting and of course the research you have to do into this kind of craft is as fulfilling as actually building the models.
I already produce a range of 1:35 Narrow Gauge loco and rolling stock kits so may add this to the range in the future, if of course time permits.
I will post some more pics of the model in a more advanced stage tomorrow.
Mark
« Reply #5 on: June 12, 2017, 11:09:39 pm »
Mark......yes those etched brass plate and section detail is very crisp :-))....I think Ian may have been concerned with weight if the models were for sailing......will they be static display only?
With the larger 5 bolted port lights, remember to keep the bolt orientation uniform between vertical and horizontal placement
Looking forward to more brasswork images
« Reply #6 on: June 12, 2017, 11:21:21 pm »
The weight did cross my mind, but did think the sheet did look quite thin, so unless it was festooned with brasss and without a load, it might be top heavy.
But given you designed it Mark, you will have factored these points into your designs.
Hesky
« Reply #7 on: June 13, 2017, 12:15:56 pm »
Hi all,
The model Is intended for static display only, although you now have me thinking!!
I was going to make it a waterline model at first but as usual with everything I do I get a bit obsessed and have to get it all, the object now is to sink the boat into foam board so I have the waterline and the depth of the hull for display (although I have modelled the rudder, propeller etc, just to see if I could do it). I plan to have a narrow gauge loco pushing tipper wagons parallel to the bank unloading coal into shoots directly into the boats.
Anyway, here are a few more pics of the build
 ww by Mark Hesketh, on Flickr
gg by Mark Hesketh, on Flickr
FullSizeRender by Mark Hesketh, on Flickr
IMG_5019 by Mark Hesketh, on Flickr
IMG_5021 by Mark Hesketh, on Flickr
More to come,
Mark
Hesky
« Reply #8 on: June 13, 2017, 05:21:45 pm »
Hi again,
Now we have the 3D printed basic hull primed and smoothed ready for casting and a coat of paint on the etched cab and engine room, the cab is separate from the hull and at this stage fully removable.
IMG_5201 by Mark Hesketh, on Flickr
IMG_5200 by Mark Hesketh, on Flickr
Casting the hull was a complete pain in that the mould is huge, about 2 ft 3" long and costly with the amount of rubber needed. Pics of the resin hull up next,
Mark
« Reply #9 on: June 13, 2017, 07:25:22 pm »
Did you make the mould as a block or as a skin with plaster case? Either way I doubt it would have been cheap. The last sack of plaster I bought cost £44 from my then local ceramics supplier.
How will you create the painted panels? These will look great when done.
Hesky
« Reply #10 on: June 13, 2017, 08:01:14 pm »
The mould is made as two part from RTV silicon rubber and I use Axson fast cast resin. Its not the cheapest but I have been making my own resin parts with this for a few years now. I suppose you get used to a certain way and if it works stick with it. I don't use degassing equipment as I can usually get away with very few bubbles if you do it right.
Not sure about the painted panels at the mo, I know they had a few but just want to see if everything fits with a basic colour scheme. I suppose I would like it to be painted as Victoria which is still running and the same class but just whatever I had available, Humbrol 174 I think.
tsenecal
« Reply #11 on: June 13, 2017, 11:20:08 pm »
Mark
2ft 3"... ???  on what planet is that huge?  :-) i have molds for a 53" type II uboat, and a 83" type VII uboat...  with full length 3 part moulds for the hulls...
Hesky
« Reply #12 on: June 14, 2017, 06:49:44 pm »
Ha ha, should have made It obvious I know little about model  boats, I only make small model railway parts the largest being a couple of inches, this is a whole new ball game for me,
Hesky
« Reply #13 on: June 14, 2017, 07:02:02 pm »
Hi all,
Bit of experimentation with the resin hull, no shrinkage to report and everything still fits fine,
IMG_5401 by Mark Hesketh, on Flickr
IMG_5403 by Mark Hesketh, on Flickr
some detail to add to the hull and a coat of paint next,
Mark
Hesky
« Reply #14 on: June 15, 2017, 11:19:02 am »
Morning all,
A bit more detail on the resin hull this morning and some hinge detail on the front hatch,
Hull to be painted this afternoon I think, some Halfords satin black found at the back of the garage!
Hatch by Mark Hesketh, on Flickr
Hull by Mark Hesketh, on Flickr
More later,
Mark
Hesky
« Reply #15 on: June 15, 2017, 11:26:14 am »
More detail on the rear of hull, I was going to wait for the decal on the side but couldnt resist it.
Obviously fictional but in a similar style to how it would have been done,
IMG_5408 by Mark Hesketh, on Flickr
IMG_5416 by Mark Hesketh, on Flickr
« Reply #16 on: June 15, 2017, 01:49:54 pm »
Mr Hesketh [& sons] would be proud of your build :-))....very professional Mark........... O0
Hesky
« Reply #17 on: June 16, 2017, 04:25:56 pm »
Thanks  Derek,
Almost forgot a pic of the rudder etc, still to source a propeller though,
IMG_5393 by Mark Hesketh, on Flickr
Hesky
« Reply #18 on: June 16, 2017, 04:56:21 pm »
Ok, now the paint on the hull has dried a bit I can start putting it all together,
The half etched planked floor has a coat of humbrol wood,
 Floor boards by Mark Hesketh, on Flickr
IMG_5424 by Mark Hesketh, on Flickr
IMG_5439 by Mark Hesketh, on Flickr
Going together better than expected, more later,
Mark
« Reply #19 on: June 16, 2017, 09:17:24 pm »
She is coming on a treat  :-) I love the rudder and mount, very ornate.
Hesky
« Reply #20 on: June 17, 2017, 08:32:08 am »
Thanks, all measurements taken from plans and photos, so its as near accurate as I can get
Hesky
« Reply #21 on: June 17, 2017, 09:08:22 am »
Hi all,
Few more parts added this morning, pics below,
IMG_5468 by Mark Hesketh, on Flickr
propeller by Mark Hesketh, on Flickr
front by Mark Hesketh, on Flickr
Should get a bit more done later,
Mark
Hesky
« Reply #22 on: June 18, 2017, 07:14:21 pm »
Hi all,
Just a bit of progress today as its far to hot in my loft, sure it wont last long though!
IMG_5530 by Mark Hesketh, on Flickr
IMG_5557 by Mark Hesketh, on Flickr
Just a couple more parts to dry and should be close to finishing in a couple of days,
Mark
Dreadnought
« Reply #23 on: June 19, 2017, 07:31:46 am »
Looking Great :-)) :-))
Hesky
« Reply #24 on: June 19, 2017, 05:39:47 pm »
Hi all,
Thanks for the comments, nearly done now, or as far as I can before it takes its place on the new display layout. It will be coal as discussed earlier but not sure of the amount of weathering it will have yet
IMG_5576 by Mark Hesketh, on Flickr
FullSizeRender 4 by Mark Hesketh, on Flickr
IMG_5575 by Mark Hesketh, on Flickr
IMG_5554 by Mark Hesketh, on Flickr
Page created in 0.692 seconds with 22 queries.
