Author Topic: setting up water monitors  (Read 3036 times)
Glyn Roberts
  • Creativity is contagious, pass it on.
« on: June 20, 2017, 02:46:51 pm »
I have built the 46 inch crash tender, and  want to fit 2 Robbe water monitors.  I have got the monitors and the pump and now need info how to pro-cede ie how to turn it on /off   what battery to use etc.   What parts do I need to purchase.
Thanks and regards Glyn
Big Ada
Re: setting up water monitors
« Reply #1 on: June 20, 2017, 05:47:57 pm »
You could use a Micro switch operated by a servo plugged in to your RX, and wire your Pump through the Micro switch to a suitable battery. Other ways are available.
Len.
Vts99
  • Clydebuilt = best built
« Reply #2 on: June 20, 2017, 06:39:09 pm »
I have the graupner weser fire boat with working monitors . Fitted a water scoop to keel then used a servo with an extended arm on it to activate a Micro switch as mentioned above . Only addition I did was to program the throw of the servo from my transmitter so it only had to move a few millimetres to activate the pump
Glyn Roberts
« Reply #3 on: June 20, 2017, 08:10:43 pm »
Thanks  Big Ada and Vts99,  Micro switch it is then.
Regards Glyn
Page created in 0.015 seconds with 21 queries.
