Author Topic: Billings Nordkap , Fun Build  (Read 19527 times)
Re: Billings Nordkap , Fun Build
« Reply #25 on: November 12, 2017, 11:21:54 am »
Getting the hull to a point of completion and starting to think about the upper works. Really pleased with the kit and although some of my work is not quite as I would like it things seem to be coming together.
« Reply #26 on: November 17, 2017, 09:49:01 pm »
I was afraid that the cabin would turn out to be a bit flimsy, but such is the quality of the kit that it is rock solid when glued together. Also it  nestles  in position very neatly and just slides into position, like pulling on a comfortable old wellington boot.
20171117_174631.jpg" border="0
« Reply #27 on: November 24, 2017, 07:17:22 pm »
another small step down the slipway.
« Reply #28 on: December 24, 2017, 06:01:02 pm »
Had a spot of bother with the kit piece of ply to fprm the hood for the exhaust stack. The ply just did not want to take up the shape required now matter how I tried. In the end I made the hood out of brass sheet and soldered it . Still took me several attempts to get the paint to an acceptable standard
« Reply #29 on: December 24, 2017, 11:55:02 pm »
Merry Christmas Baldrick.......assuming that the propeller is as supplied in the kit, however looks a little small for the hull contour cavity.....Derek
« Reply #30 on: December 25, 2017, 09:55:39 am »
Thanks Derek and I wish the same to you down there in the nether regions.
It is a replacement prop, the one out of the box was a rather nasty plasticy thing all frayed around the edges. Although of the same diameter (40mm) it is not totally to my satisfaction. I got it on the web and it is a fabricated one with flat blades rather than cast with some nice shape to the body, may swap it later.
 Best wishes for the coming year, don't bother returning our cricket team .
« Reply #31 on: January 01, 2018, 08:35:38 pm »
Time to tackle the forecastle.
« Reply #32 on: January 01, 2018, 10:46:25 pm »
what a beautiful build of a lovely trawler, and exceptional finish of a billing POF  hull.........
makes a lovely change from all these Shannon's going around, lol.
great stuff to see.
neil.
« Reply #33 on: January 02, 2018, 08:46:16 am »
great stuff to see.
neil.
Cheers Neil.
 Amazing what can be achieved over Christmas with the goggle box output achieving it's usual dismal standard.
 One problem is in using a phone camera the short lens FL gives divergence distortion , the stanchions are all upright. Must stop being lazy and dust off the Canon.
B.
« Reply #34 on: January 03, 2018, 08:21:01 pm »
one more for luck
« Reply #35 on: January 20, 2018, 07:52:44 pm »
I thought for interests sake I might try the laser level I bought some time back from Lidl to see how it worked in setting the waterline. Seems to work quite well . May use it in the future rather than the pencil and block of wood.
Found the vertical axis projection useful for getting the mast aligned square to the waterline rather than just the deck. Will now glue it into it's stool . Photograph makes it look a bit pi$$ed due to the parallax of the lens
T33cno
« Reply #36 on: January 20, 2018, 08:01:34 pm »
 :-))  Great for checking
I still put a line on though
Lovely model you're producing  :-)
BFSMP
« Reply #37 on: January 20, 2018, 08:56:13 pm »
believe it or not, baldrick, the waterlines on trawlers were not usually straight.
always painted with a roller brush on the slip way, they were usually painted, unless new from the builders yard, and the "water line" followed usually the underside of the second row of plates so ran basically parallel to the bulwark tops, and then at the bow and stern would taper down towards the sea giving a very odd shape waterline indeed.
it can be seen on these three shots of trawlers, and this fine model of a friend of mine.
so don't worry if you don't get it straight, lol.
Taranis
  • Balne Moor MBC
« Reply #38 on: June 13, 2019, 10:57:59 am »
Hi Baldrick. Could I ask does this look complete to you? I have checked the main ply sheets are there
ANDY
« Reply #39 on: June 13, 2019, 01:13:55 pm »
  I guess so Andy.   I remember thinking when I first opened my box that it looked a bit scant for what I was expecting and the box was not sellotaped shut, but it was all there. . The rather minuscule plastic prop will probably be hiding inside the lifeboat. The prop was the only thing I can recall replacing (with a brass one)  You might consider one a few mm larger as well .
regards Balders
Taranis
  • Balne Moor MBC
« Reply #40 on: June 13, 2019, 02:28:46 pm »
Thanks for that  :-))
I bought one quite a while ago on eBay that was pre lasering and a lot of the sheets were mahogany. I got a full refund for that.
So the absence of mahogany sheets threw me a bit but it seems to be complete and was described as reduced due to box damage to £249 , then because I showed interest I got a message that I could by it for £190 so I offered £150 and it was accepted  :-)
ANDY
Peter Fitness
« Reply #41 on: June 13, 2019, 11:43:25 pm »
Regarding the prop on Nordkap, I replaced the plastic original on mine with a similar sized brass prop, but later upgraded that one to a slightly larger diameter. This gave a much better performance, not fast but more responsive steering.
Peter.
Page created in 0.999 seconds with 18 queries.
