Author Topic: AirBoat Cage  (Read 4500 times)
AirBoat Cage
« on: September 16, 2017, 08:12:43 pm »
Got me an Airboat on fleabay and need to make up a Prop cage.  Anyone made one  of other than metal as not a solderer is there  some kind of plastic type rod/tube one could use .It'll be about 10''high 10''wide
Jay
jarvo
  • Etherow model boat club
Re: AirBoat Cage
« Reply #1 on: September 16, 2017, 09:13:37 pm »
Hi Jay, try the Hobbyking website, they do spares for their airboat
Mark
Tugs are for pulling
Re: AirBoat Cage
« Reply #2 on: September 16, 2017, 10:57:24 pm »
''Thanks Mark but the swamp dawg only has a 5.5'' prop  this one has a 9'' and is a much bigger  boat
Jay
Klunk
Re: AirBoat Cage
« Reply #3 on: September 17, 2017, 08:32:41 am »
On my hover craft  i have used buckets as an outside fence an also sweet tub containers (haribo). Then use wire mesh attached to the front to stop fingers going in.
full time penguin
mrlownotes
Re: AirBoat Cage
« Reply #4 on: September 17, 2017, 02:34:50 pm »
Jag at Palaform does inexpensive lightweight alloy mesh sheets for his Hovercraft
http://shop.modelhovercraft.co.uk/index.php?route=product/product&path=60_68&product_id=174
Worth a call to check sizes and availability.
Bintur Ellenbach
Re: AirBoat Cage
« Reply #5 on: September 17, 2017, 04:39:55 pm »
Thanks but don't want mesh  it will just be bars I need to make a 2 Tall Arches with bars joining not too concerned about front entry at the moment  that mesh might do for that
Hellboy Paul
Re: AirBoat Cage
« Reply #7 on: September 17, 2017, 06:46:08 pm »
Bit too rich for me I'm afraid
Hellboy Paul
Re: AirBoat Cage
« Reply #8 on: September 17, 2017, 06:48:29 pm »
You can most probably find one cheaper, i'm not going to do all the searching for you...
Re: AirBoat Cage
« Reply #9 on: September 17, 2017, 10:26:52 pm »
Never asked you to my op was if there was a material that did not require soldering sorry if I took up some of your time
grasshopper
    • A1 Hobbies Ltd.
Re: AirBoat Cage
« Reply #10 on: September 17, 2017, 10:42:05 pm »
Plastic rod of a suitable diameter, bamboo or rattan strip.....have you looked at places like B&Q in their strip materials box?
If it's not a scale model could you use a section of a plastic bucket/pot and make a duct?
Re: AirBoat Cage
« Reply #11 on: September 18, 2017, 05:39:03 am »
Thanks have already made one with bamboo spars but the 2 arches have made out of ply which coupled with a large  motor pylon and rudder have a bit of a Sail effect. Reluctant to make a duct hoping to make it all in rod might have to bite the bullet and try soldering
surfs up
Re: AirBoat Cage
« Reply #12 on: September 18, 2017, 09:15:34 am »
Have a look at EMA models lots of plastic connection. http://www.ema-models.co.uk.
david48
Re: AirBoat Cage
« Reply #13 on: September 18, 2017, 12:44:42 pm »
This fan guard you want  it will have to work as a real one I assume as well as looking ok so I would think metal would be best ,maybe plastic will not be strong enough if it lets go.
Re: AirBoat Cage
« Reply #14 on: September 18, 2017, 04:34:53 pm »
If you know anyone with a 3D printer, that is a possibility. As is cannibalising a 9in desk fan from a boot sale.
john44
Re: AirBoat Cage
« Reply #15 on: September 18, 2017, 05:45:19 pm »
Jamaic, I have made cages out of 3mm brass tube bent over a former, buiscuit tin etc
cross bars ends filed with a small round file assembly held together with garden wire
ends joining the hoops fluxed  as you go along.
You will need a blowtorch you will never do it with a soldering iron.
You can always file off the excess solder after, use bulldog crocodile clips as heat sinks
if needed. Hope this helps.
tobyker
Re: AirBoat Cage
« Reply #16 on: September 20, 2017, 08:01:28 pm »
I laminated mine from two thicknesses of thin ply over a wooden former. Seems quite strong enough with a 9" prop on a small brushless motor.
Re: AirBoat Cage
« Reply #17 on: September 20, 2017, 10:15:00 pm »
Thanks for all the input guys going to have a go with some brass tube and solder should be interesting as I hate solder
Jay
david48
Re: AirBoat Cage
« Reply #18 on: September 21, 2017, 09:38:13 am »
Tube might not be the best choice as it might kink when you form the curve ,if the radius is not too tight  , solid drawn wire might be a better choice ,did you see your PM .
David
Re: AirBoat Cage
« Reply #19 on: September 21, 2017, 11:16:51 am »
Sorry meant Tube David intending to make the upright from one size and  the curve from the next down and slip it into it least thats the plan :}
johnv
Re: AirBoat Cage
« Reply #20 on: September 21, 2017, 10:22:57 pm »
Hi you can use a cage from a old 12 volt car dashboard fan
Onetenor
Re: AirBoat Cage
« Reply #21 on: October 06, 2017, 02:47:43 am »
Plastic rod is available from Arts/Hobby supplies shops .It can be joined with plastic weld or my fave PLASTIC MAGIC  look on these links  https://www.google.co.uk/search?q=plastic+rods+and+connectors&oq=Plastic+rod&aqs=chrome.4.69i57j0l5.17109j0j7&sourceid=chrome&ie=UTF-8
Re: AirBoat Cage
« Reply #22 on: October 06, 2017, 09:01:29 am »
Wandering through Lidl yesterday, in one of the middle aisles, I saw a cake cooling rack.  Wire, circular, about 10" diameter.  Might be a start.
Re: AirBoat Cage
« Reply #23 on: October 06, 2017, 09:22:28 am »
Thanks John and Malcolm I made one from Brass tube and Mesh
Onetenor
Re: AirBoat Cage
« Reply #24 on: October 06, 2017, 03:09:03 pm »
OK well done got any pics? Bear the plastic rods in mind for future reference.Just Google "Plastic Rods"
Page created in 0.112 seconds with 22 queries.
