Author Topic: when to split  (Read 2716 times)
Rob47
when to split
« on: October 01, 2017, 04:18:58 pm »
Looking at the current builds with split hulls, they all have one thing in common in that they are fibre glass hulls.
What is the opinion on the best time to separate the hulls if building a scratch hull..  I intend to use my normal method i.e bulkheads, stringers, and the whole lot covered with thin ply and a coat or two of fibreglass tissue. finish as one then cut between the bulkheads to split or finish as two halves.   Tempted to leave it as one then cut, but open to suggestions.
I will finish this model
dreadnought72
Re: when to split
« Reply #1 on: October 01, 2017, 04:53:52 pm »
Finish (sanding to smooth) then cut must, I think, almost always lead to a better, more invisible, join. Making two halves to sub-millimetre accuracy is surely tougher? I doubt I could do it.
Planning where the joint has to go is #1 on the list. Doing it, as in HMS Agincourt, at the mid-point where the hull's widest makes a lot of sense as the sides are nearly parallel - there's less chance of a step. That said, thinking about battleships in particular, with a general lack of access to the inside of the hull through the deck, I have been musing on the possibilities of a cut nearer the stern, where the hull's halves are later keyed together with a long watertight 'box' attached to the stern chunk, allowing 'above waterline' access when dissembled, to the motors and batteries. (Turrets, lights, etc. to just plug in).
Hmmm. Does the above need a diagram?
Andy
Rob47
Re: when to split
« Reply #2 on: October 01, 2017, 10:13:05 pm »
Andy
nope, much along my thoughts, only stiff drink needed  :-))
Re: when to split
« Reply #3 on: October 01, 2017, 10:15:29 pm »
Easy peasy - insert the hull into the back of the car and pull the tailgate down sharply. Instant fit!
Rob47
Re: when to split
« Reply #4 on: October 02, 2017, 10:24:23 am »
Nice one but prob not goood idea
Bon
Page created in 0.027 seconds with 22 queries.
