Author Topic: Kingdon Boiler  (Read 4712 times)
Frank B
Kingdon Boiler
« on: October 14, 2017, 01:19:51 pm »
Hi there,
Just wondering if anyone out there has got any information available on a Kingdon type vertical boiler, suitable to drive my Marcher and Borderer steam engines?
Any information available drawings, designs, dimensions etc... would be much appreciated.
Frank
Re: Kingdon Boiler
« Reply #1 on: October 14, 2017, 09:19:14 pm »
Jim....a GOOGLE search on Kingdon Boilers offers a good number of images of builds......The British Martin Baylis Eng offers them, MacSteam just before closure made a number for sale....Nigel from Pendle Boilers would also be a starting point....[although these are boiler builders & sales people...not for plans]
From my limited understanding, the actual Kingdon boiler construction differed from horizontal water cross tubes to vertical heat tubes?...which would have suited coal burning.....again I am unsure if this carried over to model construction of Kingdon look a like boilers.....having said this, they are certainly very visually appealing for a model build open launch :-))
https://www.google.com.au/search?q=Kingdon++marine+boiler&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwiXkeXv8_DWAhUHvLwKHdlOCBkQsAQIJw
Our member KBIO from France is part way with a build and using a Kingdon model boiler...... Another member here, Bernhard BB has a beautiful open launch + Kingdon build on Youtube.......did your question in Model Engineering offer any results?
Would be interested to hear how you progress........... Derek
PS....following is from a 2015 E-Bay auction...........
This auction includes the following items:
•Absolutely brand new, never fired, 2015 Maccsteam Kingdon boiler with burner
•Maccsteam Large Kingdon boiler Operating Instructions Sheet
•Maccsteam Large Kingdon boiler Original Invoice #1694 (dated 22 January 2015)
•Maccsteam boiler test certificate complete with inscriptions as follows:
•       Boiler type:  Large Kingdon 5" and 4" diameter /6" high
•       Boiler serial number:  090115
•       Boiler capacity:  960ml
•       Construction:  All copper & silver soldered throughout
•      Number of cross tubes:  6 (six)
•       Working pressure:  80 psi
•       Tested hydraulically to:  160 lbs/psi
•        Hydraulic test date:  21 January 2015
•       Tested guaranteed by:   MACCSTEAM LIMITED (signed - Mike C. Abbott)
Frank B
Re: Kingdon Boiler
« Reply #2 on: October 16, 2017, 11:01:08 am »
Thanks for the help Derek,
I have seen the images on google - that's what made me think of building a Kingdon type boiler.
To find detailed info on them is a different matter...
I will try and contact the members mentioned below and keep you posted.
Frank :-)
Bernhard
Re: Kingdon Boiler
« Reply #3 on: February 06, 2018, 06:42:08 pm »
Page created in 0.102 seconds with 21 queries.
