Author Topic: New Springer........  (Read 13274 times)
bfgstew
  • Comfortably Numb
« on: November 12, 2017, 12:55:13 pm »
Well I have  cracked on with my new springer, not bothered with pics from the start as it is a very standard build.......until now.
I am not going to tell you what it will end up being or anything else, as it is top secret, plus it may not work. Don't worry though, as soon as I can update, I will.........I really hope this works and looks as good when it is finished as it does in my head.
SailorGreg
Re: New Springer.........???????
« Reply #1 on: November 12, 2017, 01:08:55 pm »
Given the colour scheme, my money is on a war-springer. But armed with what, that is the question!
bfgstew
  • Comfortably Numb
« Reply #2 on: November 12, 2017, 03:13:32 pm »
It's what IT SHOULD be armed with is a clue........ :-))
Should have an update later today if my planning comes together, as building from the back of a fag packet so to speak!
« Reply #3 on: November 12, 2017, 03:29:52 pm »
Players Airman
Or
Senior Service {-)
Tug Fanatic
« Reply #4 on: November 12, 2017, 04:06:26 pm »
The coaming sure allows for a large superstructure. Watching. An aircraft carrier that should have aircraft? - well apart from our two they normally do.
bfgstew
  • Comfortably Numb
« Reply #5 on: November 12, 2017, 05:19:30 pm »
You lot are to good.
Either the big E, or Tin Lizzie...........or both?
bfgstew
  • Comfortably Numb
« Reply #6 on: November 12, 2017, 07:39:17 pm »
The flight deck built and glued together, fit edging strips next, then the 2 islands. Should be fun.......I may go for the slight oversize look, not sure yet?
jarvo
  • Etherow model boat club
« Reply #7 on: November 12, 2017, 10:48:05 pm »
Dear God, with that much power available she won't need aircraft to fly!!!!!
Mind you our new carriers haven't got any aircraft any way
Mark
Tugs are for pulling
bfgstew
  • Comfortably Numb
« Reply #8 on: November 12, 2017, 11:03:53 pm »
Wait until you see the propulsion set up...................... O0 O0 O0
bfgstew
  • Comfortably Numb
« Reply #9 on: November 13, 2017, 06:44:21 pm »
Propulsion system, going to fit my thruster pod in it, will run off 6V rather than 12V, don't it to be the first submersible aircraft carrier......... :embarrassed:
bfgstew
  • Comfortably Numb
« Reply #10 on: November 13, 2017, 10:05:43 pm »
Thruster pod in position, waiting for rubber sleeves.
Rudder arrived, now need to modify the blade.
Servo and a pair of 6V batteries next on shopping list.
Then need to find some small (3" long ish), sea harrier models which should be on this vessel.
radiojoe
« Reply #11 on: November 14, 2017, 11:38:52 am »
Love the propulsion drive idea, a bit like a Seadoo, nice one,  Revell do a 1:144 scale Harrier should be close to the size you want.  :-))
Joe
Starspider
« Reply #12 on: November 14, 2017, 11:46:16 pm »
Nice drive system you'll be able to tip the harriers off the bow all I keep seeing is a Shanon doing a crash stop lol
bfgstew
  • Comfortably Numb
« Reply #13 on: November 15, 2017, 11:29:25 am »
Ok, did first bath tub test to check for any leaks, all good. Then ballasting, took 2.5kg to get to the water line, which has "xxxxx" me as I was wanting to use 2 x 6v 14ah sla batteries, trouble is these are 2.1kg each, so a total of 4.2kg.......damn.
I rather not use LiPo batteries as they need a lot of care and attention for safety reasons. Is there a better solution? Motor is a Leopard 800kv inrunner.
Look forward to suggestions.
Stewart
bfgstew
  • Comfortably Numb
« Reply #14 on: November 16, 2017, 01:48:40 pm »
Decided to use 2 x 4.5ah sla batteries instead for time being, see what run time I get off them.
radiojoe
« Reply #15 on: November 16, 2017, 02:16:56 pm »
I've got two 12 volt 1.2 ah in mine with a 540 motor it runs for hours,  ok2
Joe.
bfgstew
  • Comfortably Numb
« Reply #16 on: November 16, 2017, 02:24:10 pm »
Wow, that's good Joe.
Not sure how power hungry the brushless motor is going to be?
Gonna be fun finding out though...... :-))
bfgstew
  • Comfortably Numb
« Reply #17 on: November 18, 2017, 09:43:37 pm »
A question guys. I would like a servo that has 180 degree rotation for steering, for the life of me I cannot find one. Nothing fancy oe expensive.
Stewart
radiojoe
« Reply #18 on: November 18, 2017, 10:34:20 pm »
Hi Stewart     Hitec HS 77 BB 180° retract servo.  £19.99   if it helps.
Joe.
JimG
« Reply #19 on: November 19, 2017, 09:52:56 am »
Joe.
Better check if it is a proportional servo first. Retract servos tend to be two position only, either fully left or fully right and don't center.
Jim
Dundee Model Boat club
radiojoe
« Reply #20 on: November 19, 2017, 11:08:13 am »
Yeah the 77 is proportional the 75 is what's commonly known as bang bang, although as Stewart's using a rudder I was wondering why the 180 degree, anything over 45-50 degrees ether way and the rudder becomes inefficient. a standard servo would suffice, maybe Stewart has something else in mind.   :o
Joe
bfgstew
  • Comfortably Numb
« Reply #21 on: November 19, 2017, 03:55:56 pm »
Thanks for pointing out my error. Yes 180 is going to be wrong......DOH.
Just that a standard 60 degree servo is not going to give a great turning circle.......maybe 90 degree? Sorrg for being a dumb ass!
Tug Fanatic
« Reply #22 on: November 19, 2017, 04:03:11 pm »
I am not sure how your steering is going to be connected but the relative length of the arms on the servo & rudder will change the amount of rudder deflection available. I have never found maximum rudder angle to be a problem as there comes a point where the rudder really doesn't help by turning any more.
« Reply #23 on: November 19, 2017, 04:08:42 pm »
My Springer turns in it's own length.
Steerable Kort nozzle works for me
and my first had a fish tail rudder
which was almost as good.
radiojoe
« Reply #24 on: November 19, 2017, 04:21:55 pm »
I agree with Ned, the fish tail rudder works really well, my first Spinger practically turns on it's axis with the rudder aprox 45 degrees.
Joe
Page created in 0.288 seconds with 23 queries.
