Author Topic: Engine sound  (Read 3623 times)
john44
Engine sound
« on: January 22, 2018, 08:21:59 am »
Hi guys, does anyone out there know where I can get a PUT PUT,engine sound unit from.
john44
Re: Engine sound
« Reply #2 on: January 22, 2018, 08:33:26 am »
Thanks, mr.M, that was a rapid response.
inertia
Re: Engine sound
« Reply #3 on: January 22, 2018, 10:36:03 am »
Pure coincidence, dear boy - but we aim to please.  8)
BTW the ACTion one can be fed through a P97 or P101 amp if you need a bigger sound. I believe there will be a special offer on these amps very shortly.
DM
john44
Re: Engine sound
« Reply #4 on: January 22, 2018, 12:30:29 pm »
Thanks for the heads up Dave I will look out for it.
However the ex- techno bots guy I think he is called  Alan bond has just the thing I'm after
If I'm right he is or was a member of the Solent MBC he is now forge electronics so thank you
For the link Dave.
Best regards
richald
  • Retired and loving it!
Re: Engine sound
« Reply #5 on: January 22, 2018, 01:49:56 pm »
I use the Technobots sound generators  . .
good sound and low cost - ISTR they are Alan Bond designs.
https://www.technobotsonline.com/model-engine-sound-effects.html
Richard
Senior member of the OGG (Order of the Grumpy Gits)
Membership Number : 002
inertia
Re: Engine sound
« Reply #6 on: January 22, 2018, 03:30:51 pm »
For the link Dave.
Best regards
That's the very man, John. I've handled a couple of his units now, including an engine sound one, and they are first-class. I'm not sure, however, if the new one will do a single-cylinder diesel (PUT, PUT) sound. You can contact him via the Forge Electronics website as I think he either has or is in the process of severing his ties with Technobots due to their moving.
DM
john44
Re: Engine sound
« Reply #7 on: January 22, 2018, 06:36:53 pm »
Hi Dave, I visited his website and he says he has discontinued the separate sound units
And is concentrating on the multi sound unit.
You can scroll down the page and there are 10 sounds you can listen to, I think no6 or
No 7 sound would be the ones and the volume depends on the voltage supplying it.up to 12v
And the revs are adjustable and speed up through the throttle control.
andyquirot
Re: Engine sound
« Reply #8 on: January 22, 2018, 07:31:51 pm »
Ebay loco sound unit
inertia
Re: Engine sound
« Reply #9 on: January 22, 2018, 07:38:25 pm »
Then go for it, m'duck. V6 sounds great. He who hesitates only invites further confusion.....and if you follow my recent posts you'll find out how easy it is to vary the supply voltage - both up and down.
DM
john44
Re: Engine sound
« Reply #10 on: January 22, 2018, 09:02:33 pm »
Thank you for your advice Dave.
afb
  • FORGE ELECTRONICS
  • more wires than wood in my boats!
    • FORGE ELECTRONICS
Re: Engine sound
« Reply #11 on: February 23, 2018, 06:40:38 pm »
Just to add to the PUT PUT query, one of the Combo MK3 ''voices" is my take on a typical canal boat engine. Set to 6 cylinders it only fires twice in quick succession then pauses for 4 beats - with appropriately set tickover and top speed that should be what you're looking for. Thanks as always to DM for the recommendation!
in the land of the blind the one-eyed man is king
