Author Topic: speaker mounting  (Read 4605 times)
Rob47
speaker mounting
« on: January 28, 2018, 03:57:20 pm »
What's the best way to fit a speaker> i know it is meant to go into a box or suchlike but can find very little for use in model boats
PS space is not and issue, have around 20" beam
I will finish this model
Re: speaker mounting
« Reply #1 on: January 28, 2018, 04:12:00 pm »
I fitted mine in Exeter (Type 42 Destroyer) into a ply support and then fitted a tube (toilet roll centre) over the speaker to act as a sound box. Sorry I don't have a decent picture showing the tube fitted.
Rob47
« Reply #2 on: January 28, 2018, 04:59:10 pm »
thanks for that, think might need something bit bigger the loo roll tube  {-) but get the gist.
The Old Fart
« Reply #3 on: January 28, 2018, 05:22:28 pm »
pringles tube.
davidm1945
« Reply #4 on: January 28, 2018, 09:11:19 pm »
pringles tube.
Yep, used that, works well. Stuck to speaker using silicone aquarium sealer.
Dave.
The Old Fart
« Reply #5 on: January 29, 2018, 07:25:10 am »
or 3D print them.
Rob47
« Reply #6 on: January 30, 2018, 04:45:03 pm »
Dave.
Two narrow  %%
« Reply #7 on: January 30, 2018, 04:49:32 pm »
Carpet roll centre tube?  8)
The Old Fart
« Reply #8 on: January 30, 2018, 06:58:14 pm »
rainwater down pipe, or 4" air vent pipe.
Rob47
« Reply #9 on: January 30, 2018, 09:27:39 pm »
Needs to accommodate either 5” or 6” speakers 🔊
john44
« Reply #10 on: January 30, 2018, 09:47:11 pm »
Try gravy granule tubes they come in different sizes,waterproof with warnish, paint etc.
Any flavour will do {-) {-) .
« Reply #11 on: January 31, 2018, 11:30:51 am »
Bob,
Make a bespoke one from thin card. Cereal packet or card from an art shop or whatever you have. It doesn't have to be too robust unless you're planning on playing a recording of Joshua's trumpets  {-) {-) {-) {-) {-)
Doug
Akira
« Reply #12 on: January 31, 2018, 12:35:00 pm »
I remember a gent who built a beautiful tug here in Maine. He mounted his speaker up-side down in the hull and used the hull as the resonance chamber. It worked very impressively. Much better than the traditional system we use. I might I have taken pictures, and if I find them I will post same.
Rob47
« Reply #13 on: January 31, 2018, 04:38:16 pm »
found a speaker case with the cloth absorbing material, placed speakers in a cut out in a bulkhead, then let rip, the sound is awesome,  going to try the inverted, once happy will take a snap or two.
Page created in 0.033 seconds with 22 queries.
