I have often seen motors with their own separate mount, which is parallel to the line of the prop shaft.
Radio trays I have seen as just a flat piece of ply, or even a box, parallel to the waterline.
The biggest consideration is battery placement, if you are going to use heavy batteries, at is affects the trim and balance of the boat. If you do a search on here, there has been at least one detailed discussion of battery placement.
If you look at the masterclass builds, you will see several ideas for mounting motors, electrics and batteries.
