Pages: 1 2 3 4 5 [6]   Go Down
Author Topic: Another Sealight puffer build  (Read 33295 times)
Re: Another Sealight puffer build
« Reply #125 on: October 01, 2018, 07:48:35 am »
Evening Dom...... certainly did not realize that this still occurred on the Imara
With the advent of steam winches, for larger vessels there is absolutely no logical reason apart from tradition or security?
The other possible reason is in those same earlier days of steam winches, hauling in a link studded chain and the subsequent tension of the chain or slackness would have resulted in progressively heavier anchors crashing against the hawser opening in the hull. Many vessels display double reinforced or 'doubler plates' around the chain hawser
Today's 100,000 ton vessels have massive cast steel 'doubler plates' welded into the hull and the anchors are hauled in and housed against hydraulic relief valve presets so the anchors are secure....and then additional mechanical securing of the chain is made prior to sea
We are getting a little off the track........however security of the housed anchor on the deck is still probably the answer ;)
birlinn
  • Old git in a garage
« Reply #126 on: October 01, 2018, 02:09:25 pm »
I don't think the puffers needed to anchor very often in their trips round the Hebrides- they were usually at a pier, parked on a beach, or on a mooring.
birlinn
« Reply #127 on: October 04, 2018, 12:59:07 pm »
Finished!
Apart from wiring up the radio gear, and as I will not try sailing her until the Spring, no hurry.
Another project needed....
« Reply #128 on: October 04, 2018, 01:34:55 pm »
A model boat is never finished.... but a great job so far!   ok2
birlinn
« Reply #129 on: October 04, 2018, 01:45:21 pm »
I know- just looking at the pics, and thinking of putting a bit of stain on those working wooden blocks. The flue to the forepeak should be a bit higher.
And I probably will build a better ship's boat- I am not happy with that one.
Tafelspitz
  • Model Boat Bedlam
« Reply #130 on: October 05, 2018, 12:27:11 pm »
Sheeee's a bee-youtie  O0
Can't wait to see her sailing the seven seas.
Dom
We live in a society exquisitely dependent on science and technology, in which hardly anyone knows anything about science and technology.  Carl Sagan
ooyah/2
« Reply #131 on: October 09, 2018, 09:35:34 pm »
Phil,
A really nice model, it captures the look of the 85`ft boats, I hope when ready you don't have a hernia with the weight required to get her down to her waterline.
My model of the 66 ft boat at 1/2"- 1 ft, had to have a great deal of lead ballast as well as the steam plant to get it to sit correctly on the water.
I hope that you are surviving the weather coming in from the Atlantic, never mind tomorrow it's to be deck chairs and sun block.
George.
birlinn
« Reply #132 on: November 10, 2018, 09:32:17 pm »
I got around to scratch building another ship's boat, with better rib spacing.
Also stained the blocks, and raised the stove flue.
Not perfect, but I'm a bit happier.
Pages: 1 2 3 4 5 [6]   Go Up
Page created in 0.02 seconds with 23 queries.
