Author Topic: How to cut freeing Port smoothing  (Read 4271 times)
macz_chung
« on: July 05, 2018, 04:19:03 am »
Hi everyone,
Nice to meet to you all. I'm going to build a tug from model slipway which is AL KHUBAR. I would like to ask how to cut the freeing port accurate ?
What does the tools as i need ? :-)
Chung
John W E
  • I see no ships !!
Knowledge begins with respect
macz_chung
Re: How to cut freeing Port smoothing
« Reply #2 on: July 05, 2018, 09:38:53 am »
Hi John,
Thanks your reply. That's great idea for mark the line on bulwarks. The next step should be drill the small hole and use flat file knife to make it smooth ?
« Reply #3 on: July 05, 2018, 09:53:12 am »
I did something similar for scuppers, which are smaller. Basically cut the hole too small, and then used a piece of sandpaper glued to a flat stick for the edges, and a round file for corners. Just slowly edging out from the hole. Finally a quick clean with very fine sandpaper. NB I don't use the red oxide colored stuff, it stains.
macz_chung
« Reply #4 on: July 05, 2018, 10:26:29 am »
Hi tiger,
You provide a great method to me for my project.
chung
« Reply #5 on: July 05, 2018, 10:39:46 am »
I have also folded small pieces of sandpaper over a cocktail stick/bamboo toothpick for fine corners.
