I had originally installed an Ess one sound module in the engine compartment of my Dumas Chris Craft 1930, but the module gets quite warm and I wanted to keep the temp in that small compartment as low as possible.
So I decided to put it in the rear cockpit with its own battery in the rear steering compartment. I thought about disguising the module as a travel trunk or similar, then hit on the idea of a table that fitted with the style of the boat.
So far so good, it looks fine and the sound is clearer, but I have fastened it with velcro (both the module and the table top) and it is a bit wobbly. There is no danger of it coming loose, but just not quite right. I have used the similar product that is for hanging pictures and that is more rigid, but it is not suited to being regularly attached and removed.
I have seen industrial grade hook and loop advertised, which might be the answer, has anyone used this product, or any other suggestions?
