Author Topic: Hornby Swift Restoration  (Read 1923 times)
LJ Crew
« on: July 21, 2018, 06:35:51 pm »
I've just won (Fleabay) a Hornby "Swift" clockwork speed boat which I hope to restore. Any advice will be welcome. Thanks John
Re: Hornby Swift Restoration
« Reply #1 on: July 22, 2018, 02:04:53 am »
If you are thinking of investment, don't do any repairs, repaint, or modification. It will take a huge chunk off of the collectibles value.
If it is just for fun an use, then the only thing I can say is during disassembly expect it to try to 'explode' when you take the deck off. If the spring has shifted on its mountings it might try to break free. Work in a clear area (or disassemble/reassemble in a box), if the spring gets loose at any stage it will do so violently and could send other parts flying.
If you are going to lube, it might be better to use graphite on all working parts instead of oil. The only exception might be the prop shaft if it allows water to come in.
LJ Crew
« Reply #2 on: July 22, 2018, 08:01:06 am »
Thank you Tigertiger, the exploding spring definitely sounds like a 'elf 'hazard, but I've survived 70 odd years so something is going to get me sometime! The "purists" may disagree, but all these things were made as toys and I like playing with them.
« Reply #3 on: July 22, 2018, 09:25:52 am »
Not so much the a health hazard, but if bits go flying across the workshop, or are even displaced before you see how they fit or where they belonged, life gets more difficult.
Page created in 0.111 seconds with 21 queries.
