Author Topic: Sealing around prop shaft outer tube  (Read 3964 times)
Gardener
« on: August 03, 2018, 05:17:37 pm »
What is the best thing to use under the hull to seal around the newly fitted prop shaft outer tube to make it waterproof?
Big Ada
Re: Sealing around prop shaft outer tube
« Reply #1 on: August 03, 2018, 05:34:29 pm »
I usually blank off the Outside of the hole with Masking tape, then create a Well around the hole on the inside and pour in a 2 part epoxy Resin, having aligned the Prop Shaft and Motor First.
Others do it their way.
Len.
Gardener
« Reply #2 on: August 03, 2018, 05:35:24 pm »
 :-))  Thanks
morley bill 1
« Reply #3 on: August 03, 2018, 06:54:32 pm »
Hi I use Milliput in & outside the hull it sets very hard is watertight and can be faired in before it sets  Bill...
Gardener
« Reply #4 on: August 03, 2018, 07:02:09 pm »
 :-))  Thanks
« Reply #5 on: August 03, 2018, 07:31:12 pm »
I think it depends on the manner in which the prop shaft sleeve exits the hull. If it is a neat round hole through the stern post a bit of tape around the orifice and then stand the boat upright and pour in a bit of epoxy resin. If it is a long angled slash through the keel then I like to build up a shroud around the tube and hull to be faired in when set then a bandage of resin and tape over the inside to encapsulate the wound.
Gardener
« Reply #6 on: August 03, 2018, 07:42:48 pm »
nemesis
« Reply #7 on: August 04, 2018, 02:22:46 pm »
If it is a brass outer tube make sure that you really rough it up as brass and resin do not like each other. So you are depending on a mechanical key. nemesis
Gardener
« Reply #8 on: August 04, 2018, 02:51:32 pm »
 :-))  Thanks
Page created in 0.026 seconds with 21 queries.
