Author Topic: Old rudder hole  (Read 4602 times)
Gardener
Old rudder hole
« on: August 12, 2018, 12:55:04 pm »
what is the best thing to use to fill an old rudder hole in the bottom of the boat ?
Bought old wooden speed boat and moving the rudder to a new location ...
chas
Re: Old rudder hole
« Reply #1 on: August 12, 2018, 02:15:10 pm »
A piece of dowel, sand to close fit and coat with araldite. Insert it, wait to dry, sand and paint.
Or, a quick but slightly untidy method, a bolt, 2 washers, and a nut. Put in with some silicon sealant, keeping the sealant away from anywhere you want to paint.
Chas
Gardener
Re: Old rudder hole
« Reply #2 on: August 12, 2018, 03:09:34 pm »
johnv
Re: Old rudder hole
« Reply #3 on: August 12, 2018, 04:20:09 pm »
Hi it's John V i always glue a small bit of ply on inside to cover hole and use a body filler on out side cheers John V
Gardener
Re: Old rudder hole
« Reply #4 on: August 12, 2018, 04:46:49 pm »
Perkasaman2
Re: Old rudder hole
« Reply #5 on: August 12, 2018, 08:08:36 pm »
Another system is to tape over the hole on the outside and turn the hull over and wedge or support the hull floor level at the site of the hole. Mix some 2part epoxy resin and pour it over the site of the hole and this should seal the hole nicely. If there is a risk that the resin will spread too far you can surround the  hole first with a dam of putty or plasticene to contain the resin and achieve a good thickness. This method is often used when relocating rudders or propshafts. Once set the tape is removed easily and a bit of filler applied to smooth imperfections in finish. It's important to ensure that the tape does stick to the hull before attempting this fix. Also ensure the inner hull is dust-free and clean to assist adhesion.
Gardener
Re: Old rudder hole
« Reply #6 on: August 12, 2018, 08:11:12 pm »
Re: Old rudder hole
« Reply #7 on: August 12, 2018, 08:15:08 pm »
Not sure why this should be so complicated. Just fill up the existing hole, preferably with a piece of dowel or similar and seal the two ends with filler to blend into the hull on the outside. Five minute job.
chas
Re: Old rudder hole
« Reply #8 on: August 12, 2018, 11:36:08 pm »
It's sometimes an advantage to fill a hole in a wooden hull with wood, rather than anything else. Especially if the new hole intrudes on the filled area. A simple job however you do it, just do whatever floats your boat😂.
Gardener
Re: Old rudder hole
« Reply #9 on: August 13, 2018, 07:19:59 am »
johnv
Re: Old rudder hole
« Reply #10 on: August 13, 2018, 07:38:34 am »
Hi Dave it's John V get a bath plug cheers John V
Andyn
Re: Old rudder hole
« Reply #11 on: August 13, 2018, 10:39:53 am »
Duct tape
Gardener
Re: Old rudder hole
« Reply #12 on: August 13, 2018, 12:30:07 pm »
 :} :police:
Page created in 0.017 seconds with 22 queries.
