Author Topic: planet5 stick from sprung back to ratchet conversion  (Read 4099 times)
« on: August 15, 2018, 03:00:36 pm »
is it possible to change the right stick on planet 5Tx   form sprung central to ratchet fore and aft if so how
Rottweiler
Re: planet5 stick from sprung back to ratchet conversion
« Reply #1 on: August 15, 2018, 03:24:50 pm »
Yes it is.Planet used to make a small part with spring,that could with difficulty replace the part in the back of the radio.You may find these still around in some shops as they were never very popular it seems.I did the conversion on my radio,and it works fine.
Good Luck
Mick F
« Reply #2 on: August 15, 2018, 04:24:19 pm »
Thanks Mick  but its the spring i want rid off
Rottweiler
« Reply #3 on: August 15, 2018, 04:33:14 pm »
AH sorry!
 Im not sure but if you just go into the back and remove the spring,it should revert back to normal ratchet? Im almost sure it was only the spring that had to be inserted .Worth a try,but if it doesn't work you can always hook the tiny spring up again.
Mick F
« Reply #4 on: August 15, 2018, 04:37:55 pm »
Thanks Mick
Skimmer Fan
« Reply #5 on: August 15, 2018, 05:39:56 pm »
There is a thin strip that goes across the top of the stick unit which has to be removed to fit the spring arm and spring.
I am not very good at explaining things so I will take some pictures and post them tonight.
Skimmer Fan
« Reply #6 on: August 15, 2018, 05:47:44 pm »
Think he wants the spring removing and ratchet strip fitted.
Skimmer Fan
« Reply #7 on: August 15, 2018, 06:07:59 pm »
NetleynedI said I was no good at explaining its the piece that is removed for the spring kit to be fitted that he needs do you agree.
Skimmer Fan
« Reply #8 on: August 15, 2018, 06:27:29 pm »
http://www.modelboatmayhem.co.uk/forum/index.php/topic,43913.msg468685.html#msg468685
This link shows how to fit the spring and arm so maybe reverse procedure to revert to ratchet?
Ray
Skimmer Fan
« Reply #9 on: August 15, 2018, 06:34:28 pm »
JaymacWell I will try again.
You remove the spring and its arm.
Here is one I broke earlier. As you can see in the pictures you need a strip of metal and a screw.
If you want the ones off my broken stick I can post them to you.
Skimmer Fan
« Reply #10 on: August 15, 2018, 06:56:47 pm »
« Reply #11 on: August 15, 2018, 07:00:46 pm »
I have the opposite issue for my recently purchased Saturn set in wanting to convert the throttle from ratchet to spring. It appears that the necessary conversion kit won't be available until early September though. One option might be to transfer the spring from an unused channel to the throttle but we will see.
« Reply #12 on: August 15, 2018, 07:24:27 pm »
Correct Ned  I want the self centre  action removed and  ratchet  motion  instead, Skimmer  I'll have a look inside and see if it is  practical for my
  limited finger  movement  thanks for the offer of the bits will come back on that
Jay
« Reply #13 on: August 16, 2018, 12:31:06 pm »
Re Metal strip and screw yes please Skimmer PM sent
Jay
Skimmer Fan
« Reply #14 on: August 16, 2018, 01:49:29 pm »
In the post.
Skimmer Fan
« Reply #15 on: August 16, 2018, 02:45:06 pm »
Many thanks
Jay
« Reply #16 on: August 16, 2018, 03:02:21 pm »
 :-)) >:-o :-)) :-)) :-))
Another great example of the help and
generosity to be found on Mayhem.
« Reply #17 on: August 16, 2018, 04:08:27 pm »
You can say that again Ned :-))  but why the >:-o  ?
« Reply #18 on: August 16, 2018, 04:59:10 pm »
My phone has a mind of it's own >>:-( >>:-(
Just great you're fixed up Jay
« Reply #19 on: August 16, 2018, 07:02:29 pm »
 :}  got the same problem with my fingers Ned
« Reply #20 on: August 17, 2018, 12:27:07 pm »
Wow Skimmer  arrived this morning now fitted and working great many thanks again if you   let me have your address will reimburse or I can pop it in the RLNI box. Thanks also to all for their the input and pics
Jay
Skimmer Fan
« Reply #21 on: August 17, 2018, 12:35:03 pm »
RNLI box will do.
Glad we solved your problem. :-))
Skimmer Fan
« Reply #22 on: August 17, 2018, 01:04:12 pm »
Will Do :-))
Page created in 0.025 seconds with 22 queries.
