Author Topic: Hand Pump  (Read 3183 times)
kiwimodeller
Hand Pump
« on: September 04, 2018, 09:56:29 am »
Hi, can anybody steer me towards some drawings for a hand operated boiler top up pump please. It will be mainly used for bench top work although I might put one in a boat to make it easier to refill the boiler at the lake side. Have checked my Harris book and a couple of others but they are all talking about engine driven pumps. I just need bore, stroke, lever lengths and a design for the non return valve for a manual pump. Cheers, Ian.
Re: Hand Pump
« Reply #1 on: September 04, 2018, 10:50:47 am »
Ian......without machining facilities and the need to confirm a hydrostatic boiler test, I chose a different path which serves both of your needs
1. a Microcosm M6 hand pump for ~~$68.00
2. disguise it as a permanent part of the water system
It served both purposes of the boiler test and also the test on the boiler feed water system after any pump in the system
The Crew Member manning the pump is extra...........
Re: Hand Pump
« Reply #2 on: September 04, 2018, 01:40:41 pm »
I love it  O0
Re: Hand Pump
« Reply #3 on: September 04, 2018, 08:20:37 pm »
page41image2930960
With luck the drawing should be big enough, if this helps, I can send you a better drawing if you PM me your e mail address
Phil
Re: Hand Pump
« Reply #4 on: September 04, 2018, 08:25:26 pm »
OK that didn't work, stupid cut and paste. I will re do it and post tomorrow
Phil
kiwimodeller
Re: Hand Pump
« Reply #5 on: September 05, 2018, 02:43:26 am »
Is that an Australian crew member Derek? It looks like he BEARly has enough strength to push the leaver!! %%
Re: Hand Pump
« Reply #6 on: September 05, 2018, 03:25:36 am »
As the first member of the crew [and I understand he is a Bear], but has been Christened 'Bilge Rat 1.......he tries to fool me with different colour jackets  {-).....
rhavrane
  • Steam passionate collector
Re: Hand Pump
« Reply #7 on: September 05, 2018, 08:14:30 am »
Bonjour,
On this launch, I have installed a Pendlesteam hand pump : https://www.youtube.com/watch?v=0cyZ_F29vd4
Raphaël
frazer heslop
Re: Hand Pump
« Reply #8 on: September 11, 2018, 10:23:35 pm »
Several pump drawings on this site the hand pump is further down the page.For some reason its showing a wee bit small
http://www.vapeuretmodelesavapeur.com/groupederubriqu9/index.html
Page created in 0.021 seconds with 22 queries.
