Author Topic: Wiring Diagrams  (Read 21002 times)
Ghost in the shell
Wiring Diagrams
« on: September 20, 2007, 01:04:34 pm »
based on some information that has been asked, This is a wiring diagram thread.
Please keep them simple and easy to follow.
2 batteries parrallel with 2x speed controllers using a seperate battery pack to supply Rx
Go Nuclear!  you'll love it
Ghost in the shell
Re: Wiring Diagrams
« Reply #1 on: September 20, 2007, 01:15:51 pm »
Two Channel setup using seperate battery pack and BEC enabled reciever such as Mtroniks "VIPER" or the Proboat Tornado 50
Ghost in the shell
Re: Wiring Diagrams
« Reply #2 on: September 20, 2007, 01:18:27 pm »
One Motor, One battery, BEC type ESC supplying power to Rx,
Ghost in the shell
Re: Wiring Diagrams
« Reply #3 on: September 20, 2007, 01:23:45 pm »
One battery with ESC supplying power to RX, two motors Parrallel wired
maninthestreet
Re: Wiring Diagrams
« Reply #4 on: September 21, 2007, 11:44:59 am »
Very useful!  O0  O0
Can you please do one for a non-BEC ESC (or a mechanical SC), with a BEC-enabled receiver taking it's power from the motor drive battery, powering a single motor?
Re: Wiring Diagrams
« Reply #5 on: September 21, 2007, 01:40:46 pm »
Unless someone knows better, BEC receivers should not be used above 7.2 volts nominal (6 cell nicad pack).  RX makers are happy to put a BEC sticker on the case, but are remarkably shy about just what their built in BEC is capable of.  If the main battery is 6 volt, that is what model radios were designed around in the first place (4 dry cells or 3 lead acid cells, both 6 volts, a happy co-incidence), so no extra components are needed.  Higher than 6 volts, several manufacturers offer a separate BEC, either kit or ready-built.
Ghost in the shell
Re: Wiring Diagrams
« Reply #6 on: September 21, 2007, 01:59:47 pm »
Very useful!  O0  O0
its identical to the bec type esc, however the red wire isn't pulled from the servo-plug on the esc.
maninthestreet
Re: Wiring Diagrams
« Reply #7 on: September 21, 2007, 02:16:01 pm »
Very useful!  O0  O0
Maybe I confused you - the receiver would have no separate battery pack here - it's getting it's power supply from the motor drive battery (because the receiver is BEC enabled).
Ghost in the shell
Re: Wiring Diagrams
« Reply #8 on: September 21, 2007, 02:25:28 pm »
man in the street, look at reply #2. each part is labled.
maninthestreet
Re: Wiring Diagrams
« Reply #9 on: September 21, 2007, 02:54:23 pm »
Well, the diagram in Reply #6 has an extraneous receiver battery/connection, compared to diagram in Reply #2.
Ghost in the shell
Re: Wiring Diagrams
« Reply #10 on: September 21, 2007, 02:58:26 pm »
thats because I was using a bec type esc (Mtroniks VIPER 15 for example), when you run this type of esc with a seperate battery for the rx, you must remove the red wire from the servo-plug, hence the red wire being shorter than the other two.  a relay or mecanical type esc doesn't feed power to the rx and so needs to have all 3 wires in place as the relays are powered by the rx power source.
Page created in 0.823 seconds with 18 queries.
