Pages: [1] 2 3 4 5 6 7   Go Down
Author Topic: HMS Clyde build  (Read 55916 times)
stuart22
HMS Clyde build
« on: September 21, 2018, 08:45:49 pm »
I think its about time I started to show my build off the HMS Clyde 1/48th, its taking a long time but I am getting their. As you can see I have done all the hull work cutting openings and fixing props shafts etc. she will have working bow thruster and stern thruster. running on two electric motors 24v
Starting the super structure from A3 Plasticard 2mm sheets taken measurements from the plans this being the first time I have done this. pictures to follow once I remember how to down size them.
T888
Re: HMS Clyde build
« Reply #1 on: October 14, 2018, 02:56:27 pm »
Hi  Stuart22
I've completed HMS CLyde at this scale, if you need any help please let me know.
If you do a search for 1/48 HMS Clyde & Build Update HMS Clyde, on this forum you will see some pics of my build which may help.
Regards David
stuart22
Re: HMS Clyde build
« Reply #2 on: October 14, 2018, 03:24:07 pm »
Hi T888 we met at Netley Marsh still trying to get pictures loaded, I've been working so not had much time hopefully soon. its coming along fine. I have seen your model and taken picture's looks amazing cheers.
T888
Re: HMS Clyde build
« Reply #3 on: October 14, 2018, 03:37:11 pm »
Hi Stuart22,
That closes the loop. :-))
I've used Speed 850 motors running on 12volts and the model performs well, so you may not need 24v
Regards David
J.beazley
  • The building never ends
Re: HMS Clyde build
« Reply #4 on: October 14, 2018, 06:28:38 pm »
I run my (sister ship) HMS Mersey on a pair of MFA 800 motors works for me on 12v, did try the 850's but didnt notice that much difference apart from current draw.
They do make great boats on the water at 48th scale.
Jay
stuart22
Re: HMS Clyde build
« Reply #5 on: October 15, 2018, 08:31:37 pm »
The only reason for 24v is I have had the motors and speed controllers from Action for some time just need to use them. pictures will come soon to make this interesting %% dam annoying. <*<
peterfleet
Re: HMS Clyde build
« Reply #6 on: October 23, 2018, 07:43:19 pm »
Hi i have a clyde which is 80% finish but some picture would be helpful i try to look for yours on mayhem but could not find then
thanks
peter
T888
Re: HMS Clyde build
« Reply #7 on: October 23, 2018, 08:14:00 pm »
Hi Peter,
Were you looking for Stuart22 or mine ?
Regards David
stuart22
Re: HMS Clyde build
« Reply #8 on: October 23, 2018, 08:30:13 pm »
Sorry guys I will try again very soon to get the pictures on. I have been working on her in the last few days all railings done steps done, nothing is fixed yet just making sure all fits correctly.
peterfleet
Re: HMS Clyde build
« Reply #9 on: October 23, 2018, 09:14:00 pm »
I don't mind who ever got some picture under hel deck would help me
peter
stuart22
Re: HMS Clyde build
« Reply #10 on: October 26, 2018, 08:17:37 pm »
lets try this
stuart22
Re: HMS Clyde build
« Reply #11 on: October 26, 2018, 08:26:00 pm »
It works so here we go will post rest tomorrow.
stuart22
Re: HMS Clyde build
« Reply #12 on: October 27, 2018, 08:42:19 am »
all fittings are not fixed yet just pushed in to place please see more picture.
stuart22
Re: HMS Clyde build
« Reply #13 on: October 27, 2018, 08:46:24 am »
more to see
stuart22
Re: HMS Clyde build
« Reply #14 on: October 27, 2018, 08:50:30 am »
and so on
peterfleet
Re: HMS Clyde build
« Reply #15 on: October 27, 2018, 12:58:57 pm »
Thank you for the picture there a get help
T888
Re: HMS Clyde build
« Reply #16 on: October 27, 2018, 01:05:23 pm »
Gents,
Good job Stuart22, hope the picture you have of mine at Nettley will help you in this good build log.
I'll update the posting of my HMS Clyde with some more close details of the model as I don't wish to interfere with this build log. This may help you both.
Regards David
stuart22
Re: HMS Clyde build
« Reply #17 on: October 27, 2018, 02:34:28 pm »
Thanks T888 that would be great. phew more pictures up to date now.
stuart22
Re: HMS Clyde build
« Reply #18 on: October 27, 2018, 02:51:33 pm »
I will be using the fittings that come with the kit. using the davits sets these are a project in them self's and do look good more detail to add yet see below, the gun kit is not bad to but needs some work. I did get the stations made of stainless steel these are excellent and strong. the helideck surrounding gates will hopefully be working and also round the gun deck. looking forward to final painting main hull and deck.
stuart22
Re: HMS Clyde build
« Reply #19 on: October 27, 2018, 05:18:05 pm »
I have decided to have the superstructures remove separately in 3 parts this will allow me to have all electrics in each section hopefully. top section all mast lights and radars. second cabin lights and bottom section working gates gun deck lights.
stuart22
Re: HMS Clyde build
« Reply #20 on: October 27, 2018, 05:21:29 pm »
phew pics of inside the hull still lots to do.
peterfleet
Re: HMS Clyde build
« Reply #21 on: November 08, 2018, 10:01:58 pm »
Thanks for the picture a great help
peter
stuart22
Re: HMS Clyde build
« Reply #22 on: November 17, 2018, 05:46:10 pm »
Decided to cover forward sides with 0.5mm plasti card for a smooth finish and to fix the angled supports with liquid weld and will do the same on each main side deck walk ways.
stuart22
Re: HMS Clyde build
« Reply #23 on: November 18, 2018, 04:22:42 pm »
After the sides and fairleads are fixed I will be fixing 5mm strip around bow top as plan shows.
justboatonic
Re: HMS Clyde build
« Reply #24 on: November 18, 2018, 07:27:54 pm »
Very nice! These ships look impressive in 1\48 scale. Are the fitting self made, Sirmar other?
Pages: [1] 2 3 4 5 6 7   Go Up
