Author Topic: Cutting scuppers  (Read 4106 times)
g4yvm
Cutting scuppers
« on: November 28, 2018, 09:39:04 pm »
I need to cut the scuppers along the length of my gf hull for Breeze.  About two foot long, 1/4" wide and with just about every possible opening for a right cock up.  I assume that I cut with the dremel disk and file smooth afterwards.  The tutorial hereon suggests a diamond wheel...I have lots of those brown wheels...will they do?  The hull at this point is only about 1/16th thick.
David
Re: Cutting scuppers
« Reply #1 on: November 28, 2018, 10:36:21 pm »
David...
Those 20 diameter diamond dust wheels are cheap as chips [$8.00 for 5 wheels from e-Bay] ...the diamond wheel will make a clean cut & make dust of the parent material......the brown fiber wheels may make a tear cut & form a melted burnt paste & grab <*<
The only way to determine is to try the fiber wheels
g4yvm
« Reply #2 on: November 28, 2018, 10:37:47 pm »
Cheers Derek,
yes I intend to try the brown disks first...probably end up with diamond at the end of the day.
Klunk
« Reply #3 on: November 28, 2018, 11:15:27 pm »
mark out where each scupper is, eye up to ensure it looks correct, remeasure then  drill 2 holes 1 at each end of scupper inside the line, cut with diamond disk then file to correct aperture size, time consuming, but take it slow and careful and you will get there
full time penguin
g4yvm
« Reply #4 on: November 28, 2018, 11:27:29 pm »
Thanks.
And am I wise to cut the scuppers before adding the margin planks?  Ive weighed up the pros and cons but have settle on cutting scuppers, then adding the beams, then tha margin and deck planks.  Is that the right order?
David
Perkasaman2
« Reply #5 on: November 29, 2018, 08:37:42 pm »
Wear a dust mask if you are cutting or filing as the dust is harmful and is an irritant.
g4yvm
« Reply #6 on: November 29, 2018, 08:43:54 pm »
D
SailorGreg
« Reply #7 on: November 29, 2018, 10:02:07 pm »
Thanks.
David
You want the bottom edge of the scuppers flush with the deck planking, so unless you can measure and cut very accurately I suggest it is better to leave finishing the scuppers until you have laid the deck. That way you know exactly where to end your filing.
Greg
g4yvm
« Reply #8 on: November 29, 2018, 10:15:58 pm »
Cheers Greg.
D
Page created in 0.164 seconds with 22 queries.
